Factory AC
Old Apr 20, 2020 | 06:35 PM
blackelim's Avatar
blackelim
Factory AC
I want to swap my evaporator housing for a different one that is in better shape.1974 F-250 390. Is it possible to R&R them with the motor in place ? It looks like it will clear everything but I want to make sure.
Thanks
Old Apr 21, 2020 | 10:58 PM
trooper73's Avatar
trooper73
8th Gear
You can R&R with the engine in place, it will be tight but it’s doable. Good luck finding a box though, I ended up just restoring my box and replacing/cleaning all the components inside. Here’s a good video on removing and installing the box:
Old Apr 22, 2020 | 12:39 AM
blackelim's Avatar
blackelim
Thanks for the video, that makes it look possible with the 390.
I already have a different box thanks to a parts truck that I bought. I am cleaning it up now and trying to find a copper and brass heater core. I want to change everything at once and only once. (I hope)
Old Apr 22, 2020 | 01:32 AM
trooper73's Avatar
trooper73
8th Gear
https://www.npdlink.com/product/heat...x/146337/50788
I had a heck of a time finding one too but finally found one, this is the only reproduced copper core i was able to find. Your only other option would be to find a NOS one but idk the oart number for that. The NPD one is identical to my original heater core though, I just carefully cut off the original moldings to put on the new one and it fit perfectly
John Bond
Jun 13, 2016 08:56 AM
Country705
May 23, 2009 10:55 AM
77 ford shortbed
Jun 6, 2008 03:51 PM
Country705
Feb 18, 2007 03:05 AM
rebelbob
Apr 2, 2002 08:15 PM
