Bed tie downs
Old Apr 19, 2020 | 09:12 PM
Shortbox4x4's Avatar
Shortbox4x4
Bed tie downs
Anyone have any thoughts and or pictures of putting some sort of bed tie downs in the bed but I don’t want to drill holes in the box/bed at all.
So with that being said.....how about some sort of a d ring I could run the box bolts thru that go thru the frame?
I want something strong enough that I can put a ratchet strap to so I can tie things down like a ATV in the back of the truck.
Again I don’t want to drill holes into the box anywhere or cut anything up at all.
Old Apr 19, 2020 | 09:30 PM
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
Sounds like you answered your own question.
Old Apr 19, 2020 | 09:54 PM
440 sixpack's Avatar
440 sixpack
I hear you on drilling holes, however the factory tie downs are an option. since they are original the holes belong there.
Old Apr 20, 2020 | 03:00 AM
Shortbox4x4
I did find some on Ebay but not sure of the quality. Also I didn’t know of any made specific that would fit our model year trucks.
Old Apr 20, 2020 | 03:03 AM
Shortbox4x4
Not sure of what factory ones tie downs where an option? You mean the chrome plated t hooks that mounted on the outside of the box and tailgate? My truck doesn’t have any factory holes on the outside of the box per say. Unless there is another factory tie down bracket that I don’t know about? The t hooks are the only factory ones that I know of?
Old Apr 20, 2020 | 06:30 AM
Shortbox4x4
Had a thought. Think I will buy 4 welded able D rings. Like you would weld to a bumper. Make a 1/2” thick washer. Get some longer grade 8 bolts and welded the D ring to the washer and top part of the bolt. I’ll put them in each corner of the bed hold down bolts. I’ll investigate it more. If I do it I’ll update the post as to how they turned out.
This way no modifying the box or drilling extra holes etc...
Old Apr 20, 2020 | 08:48 PM
440 sixpack
yes the T hooks are the only factory ones. it would be very easy to install them , Dennis Carpenter has them. I never really cared for them but my high boy had them from the factory, I don't ever use them but I think they're kind of classy now that I'm used to them.
Old Apr 21, 2020 | 01:45 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Old Apr 21, 2020 | 03:21 AM
Shortbox4x4
Rich, I did see those and thought about them but they just didn’t look strong enough. Guess I’m over thinking it. I didn’t think of looking at the bed stake pocket for a hole. I’ll check it out later today. Thanks! Later, Frank
Old Apr 21, 2020 | 06:33 AM
77&79F250's Avatar
77&79F250
Those were just a fast find on the internet to be an example, I am sure with more than a 30 web hunt you can find some HD ones. On the front stake pocket there is a single OEM hole (facing inwards), nothing on the middle stake pocket, but a nice flat surface to work with. And the rear stake pockets has 2 OEM holes. Of course with the proper metal plate/big washer reinforcement you should be ok to tie down a common 4 wheeler.
Old Apr 21, 2020 | 09:38 AM
tlrtucker's Avatar
tlrtucker
I've been using the stock tie downs in the corners by the cab as well as the stake pockets to tie down motorcycles and atv's for years. I've never needed anything additional and they've never shown any sign of being over stressed.
MrMajestyk
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Mar 12, 2020 12:39 PM
rich gill
Nov 28, 2009 07:43 AM
emgee
Nov 5, 2008 07:52 PM
JoSHN
2004 - 2008 F150
13
Aug 11, 2008 07:47 PM
Ringo Fonebone
General Automotive Discussion
37
Jun 6, 2005 07:14 PM
