I just purchased a 2002 Explorer XLT (woo whoo), but I got if from a toyota dealer and there is no keypad code for it. I have searched the Internet and this forum for clues on where to find the keypad code for the 2002 model year, but no luck. Does anybody know where to find the code? Any help is much appreciated.
I have looked all under both dashes on our 02 Explorer,cannot see any code,looks like a trip to the dealer,to put it on the comp,please keep us posted of any info.Phil
Check rear access panel(where your jack is located). On my 98, there is the white box (computer) and a sticker on it with the 5 digit code. It's sort of hard to read at an angle. Hopefully this helps. This will be the factory preset code.
2002 Explorer - remove plastic trim, "C" pillar, passenger side, behind rear door, then pull out on lower trim piece and you should see it. This is what I was told.
