Trailer inside lights don't work
Old Apr 17, 2020 | 12:19 PM
Crotchety Ford truck only's Avatar
" Running lights on" that would be trailer running lights ? If so backup and emergency work too ? If so I have never had a ("factory wired") trailer interior light w/o a switch. Is 120V inside also ?
Old Apr 17, 2020 | 12:20 PM
minke's Avatar
minke
Originally Posted by SDcrewzer
Frankly, I’m not sure about what it takes to get the @#&$% “smart” trailer circuit controller to work. Assuming your truck’s trim is higher than XL, here are some things to try:
Is the trailer connection wiring in an XL different from the rest of the SD line?
Old Apr 17, 2020 | 12:47 PM
78pace's Avatar
78pace
Both truck and trailer running lights. 12v on the whole trailer. It's a 30' cargo trailer
Old Apr 17, 2020 | 01:35 PM
crewzer's Avatar
crewzer
Lightbulb
My understanding from the Order Guide and the OM fuse chart is that SRW trucks not equipped with the trailer brake controller feature (i.e., base XL model) require a relay in power distribution box position #37 and a 30A fuse in position #27.
The optional TBC (including the “Smart Trailer Tow Connector”) is option code 52B.
HTH,
Jim / crewzer
Old Apr 17, 2020 | 02:00 PM
minke's Avatar
minke
HTH,
Jim / crewzer
Thanks for the answer. Perhaps you can elaborate more. I have a '17 XL F-350 SRW that I bought off the lot on the condition that they add the factory TBC.
1½ years later I still haven’t tested it. IIRC there was a time when the factory TBC had a connection to the brake master cylinder. I don’t know if that is still true. What I really want to know is if my “factory TBC" installed by the dealer is functionally the same as a factory TBC installed at the factory.
thanx,,,
Old Apr 17, 2020 | 03:42 PM
crewzer's Avatar
crewzer
Unhappy
I wish I had a definitive answer, but I don’t. While I believe that the OEM TBC can be retrofitted and enabled (see YouTube videos for installing the TBC into the F150), I don’t know if that automatically includes installation and enabling of the Smart Trailer Tow Connector.
Sorry...
Jim / crewzer
Old Apr 17, 2020 | 05:49 PM
minke's Avatar
minke
Jim / crewzer:
Thanks. I appreciate your effort.
Old Apr 18, 2020 | 10:49 AM
78pace's Avatar
78pace
Duplicate post
Old Apr 18, 2020 | 11:13 AM
78pace's Avatar
78pace
HTH,
Jim / crewzer
I I saw that as well and thought about it but mine has the built-in brake controller and it's a lariat drw
Old Apr 18, 2020 | 12:29 PM
78pace's Avatar
78pace
Problem solved. Pulled every fuse for trailer system out and all looked good no blown fuse. Replaced all of them just to sure and apparently one of them was bad even though it wasn't blown. Thanks for all the help.
Old Apr 18, 2020 | 12:37 PM
minke's Avatar
minke
Sometimes ATO / ATC fuses can be expired but visually OK. They should be checked with an ohmmeter.
Old Apr 18, 2020 | 02:48 PM
SlikWillie's Avatar
SlikWillie
I have the same issue. Do you know which fuse it was?
Old Apr 18, 2020 | 02:57 PM
  #28
crewzer's Avatar
crewzer
Thumbs up
Thanks for the update!
Stay safe,
Jim / crewzer
Old Apr 19, 2020 | 12:09 AM
  #29
78pace's Avatar
78pace
#65 it's a 30a small canister fuse
darylksu
Apr 12, 2019 11:59 PM
Horsehaulin8
Jun 8, 2018 10:07 AM
Kelpy1
Mar 9, 2017 09:31 PM
BassFantasizer
Feb 11, 2014 07:27 AM
Brcuda
Sep 22, 2008 07:52 PM
