Can anybody point me in the right direction toward what kind of computer, MAF meter, and injectors I should use for my 351w roller with c/6 transmission. This is a 4x4 F-250 3.55 gears which will be used for actual truck duties such as hauling and towing, not burning up the drag strip.
I am using long tube headers, GT40P heads, Comp 35-349-8 roller camshaft, GT-40 lower and upper intake, with 75mm single throttle body.
I am leaning towards some type of a Ford MAF, 5.0 injector harness + 5.0 cobra or bronco computer, but I am lost as to which weight injectors and computer I should use to make use of these bolt-ons. I am leaning towards a mustang computer, but then I feel that the "tune" would be geared toward a small lightweight car. Are there other options that EEC-IV?
That is a 300hp motor give or take so 24lb injectors is plenty, and a Mustang computer would do a great job with a 72mm MAF sensor and some tuning. A Pimpx computer might be easier overall though.
Would 40 pound injectors be overkill?
Are you taking it somewhere to have it tuned, or do you plan on doing it yourself?
Thanks all for the replies-- I am itching to get this thing back together. I am leaning towards 24 pound injectors and ECU + MAF from a 5.0 cobra w/ manual trans. That should do it right? I am a bit disappointed to hear that I'll only be getting 300 HP out of this, figured at least 350.
I would be open to getting it tuned but I don't know shops do that around here. Tuning requires a shop to drive/dyno it, correct?
PimpX is enticing, but the cost really dampens my enthusiasm--would cost more than my long block so far.
I try to DIY everything I can within reason. This is an low-buck build. Most of the parts I have gotten used.
I ordered a 95 Cobra 5.0 ECU, found 24lb injectors with calibrated 76mm MAF plus "BBKcold air intake" used, and I will be pulling the entire engine wire harness from a 95 5.0 Bronco. These cobbled together should get me going?
If you just want a simple setup, the A9L EEC from a Mustang GT will work just fine, but it and/or its MAF sensor need to be tuned to work with 24# injectors. That computer should work fine with the standard MAF and 19# injectors, but they may be running right at their limits to support 300HP at the flywheel.
If you can find a X3Z EEC and MAF from a 1993 Cobra, they should work with the 24# injectors with no modifications. This will easily support 300HP, with headroom up to 380HP.
