Driveshaft fitting Lube
Apr 14, 2020 | 10:11 PM
How many fittings are there to lube on my 19 F350 dually 4x4? Looked in owners manual and can’t find it. Is there a diagram of where it’s located ? Thanks !
Apr 14, 2020 | 10:16 PM
Not positive if the same.... but my 250 only has 2 behind the front tires steering knuckle, that's it.... you can rotate the joint and then you will see the fitting.
dealer didn't know they were there LOL , I had to show them. they told me there were NO zerk fittings.
Apr 14, 2020 | 10:25 PM
Apr 14, 2020 | 10:47 PM
Quote:
Originally Posted by
Truckie256
What is the recommended lube and lube schedule on those?
Apr 14, 2020 | 10:48 PM
Only two zerk fittings on SRW trucks, as was stated above. Both are on the front axle u-joints. It seems like there should be more, but there aren't.
Apr 14, 2020 | 10:55 PM
ForCal
The owner's manual calls for Motorcraft XG-11 but also says it must meet specification WSS-M2C192-A. This was discussed in this thread:
https://www.ford-trucks.com/forums/1...-fittings.html . But we didn't really come up with a definitive answer. I stick to a grease that says it's used for u-joints.
ForCal
I treat them like the age old, ( lube, oil, filter) can't hurt
hopefully one of the dually guys chimes in and gives any other zerk fitting locations that a dually might have
Apr 14, 2020 | 11:18 PM
Ok. Thanks all. Will have dealer do it on next oil change.
Apr 15, 2020 | 05:15 AM
DRW F350 just has two zerks. I lube them every 15K since they are not always turning.
Apr 15, 2020 | 05:22 AM
senix
Oh they are turning...they just aren't being powered.
Apr 15, 2020 | 05:24 AM
ATC Crazy
Turning if the front end is locked it as how I always thought it to be.
Apr 15, 2020 | 05:44 AM
There is only 2 on front.
Apr 15, 2020 | 06:05 AM
senix
Fluid dynamics in the transfercase, and the slight friction at the hubs cause the front components to spin even if the hubs are unlocked.
Here's a good video:
Apr 15, 2020 | 10:10 AM
Hey Truckie- The grease goes
inside the u-joint!
Apr 16, 2020 | 10:44 PM
