adjusting speedometer for larger tires
Old Apr 14, 2020 | 09:54 AM
quicker1's Avatar
quicker1
Looking to go from stock to 275/65/20 (34.1" and 7.9% increase over stock diameter). Years ago we used to change out speedo gears? on side of transmission to re-align speedo. How do we make this adjustment with these trucks? or does everyone just leave it alone and know they are doing about 5 mph more with larger tires when their speedo reads 60mph?
Old Apr 14, 2020 | 11:54 AM
Tuquala's Avatar
Tuquala
Since the speedo pickup is located in rear differential, the dash reading is through the trucks computer. But, you already knew this, right??!!
A dealer can usually adjust through the computer connec up to a certain amount. You could also buy a "tuner" as they usually have a way of adjusting for the change. OR, as you already mentioned, set a base for what your reading is vs true speed.
Old Apr 14, 2020 | 01:55 PM
RPhil's Avatar
RPhil
Forscan is free (the last time I checked) and can adjust your speedometer. I believe I used this link as guidance when I adjusted mine: https://forscan.org/forum/viewtopic.php?t=6346.
Good luck!
Old Apr 15, 2020 | 08:46 AM
RazorsEDGE's Avatar
RazorsEDGE
Forscan will do it but you have to have an ELM327 adapter and the paid version of Forscan, although it's cheap.
Old Apr 15, 2020 | 08:53 AM
ford390gashog's Avatar
ford390gashog
The free version of forscan will do it. The paid forescan lite will not. Unless you mean paying for the extended license? You can get a two month free trial.
Old Apr 15, 2020 | 08:56 AM
RazorsEDGE's Avatar
RazorsEDGE
Yes. PC version extended license and you are correct.
Old Apr 15, 2020 | 03:52 PM
quicker1's Avatar
quicker1
thanks guys
Old Apr 15, 2020 | 08:59 PM
RoberDen's Avatar
RoberDen
Originally Posted by quicker1
thanks guys
I have 285/65R20 and used FORScan to adjust my speedometer. My tires are 34.4 in diameter. I set the revs/mile constant to 620 and it is spot on vs.GPS speed. You may need to tweak the revs/mile a bit but I start there and adjust up or down.
Old May 14, 2020 | 01:56 PM
Capt. Ted's Avatar
Capt. Ted
295/65/R20
Has anyone used the Forscan to adjust speedometer to 295/65R20's on a 2017?
It's been a long time since I set my other variables with Forscan. I could use some help again.
I was surprised my dealer couldn't change it. They suggested:
FORD INLINE SPEEDOMETER CALIBRATOR (17-20 F-250 / F-350 / F-450)
Would this be easier than relearning Forscan?
Old May 14, 2020 | 11:43 PM
SmackDaddy's Avatar
SmackDaddy
You are in the Excursion section, I recommend posting this in the correlating section for your truck or maybe a moderator can move it.
Ltngdrvr
6.7L Power Stroke Diesel
34
Apr 25, 2014 12:03 AM
deljac
2009 - 2014 F150
Mar 9, 2013 08:20 PM
dalejr
Dec 17, 2008 10:56 AM
nitropolaris2
1997 - 2003 F150
Nov 2, 2004 11:40 PM
cocot
Oct 10, 2003 11:35 AM
