Originally posted by Rockledge Hi fordman, welcome to FTE!
A '99 Ranger does have an Octane Adjust Shorting Bar.
I'm going to look again on my Ranger for the Octane Adjust Short Bar. I was looking over the engine on my '94 SHO today and I saw it hanging there among other wires, which might be where I thought I saw it on my Ranger. That is why I thought it should be on your '99 Ranger (since mechanically the '98 and '99 models are virtually identical) ...now I'm not so sure where (or if) I saw it on my Ranger.
Tommorow should be bright and sunny so I will try and take a good look then, and I'll let you know what I find.
Rockledge, if you're so kind and when you find it, can you tell me if the bar is plastic entirely or does it have metal connectors to complete the circuit.
Well, this morning I looked real good for an Octane Adjust Short Bar on my '98 Ranger and I could not find one.
I'm not sure if that means that newer Rangers don't come with them, or if the 4.0L motor does not come with them.
When I get my 3.0L vulcan Taurus back on loan from my sister, I will check for an octane short bar on that engine. Also, I'll try to remember to take a better look at the one on my '94 SHO to see how it's made up.
I have a '99 Ranger and I belive the "jumper" at the end of the Octane Adjust Shortening Bar has been removed. If this is the case, does anyone know where I could purchase a new "jumper" for the end of it instead of manually shorting it out with a piece of metal, etc. Just need the jumper only.
Wow, this is great. I hope my '92 Aerostar 3.0 has one because it pings and I can't loosen the badly rusted distributor hold down bolt. Thanks.
I don't think my Aerostar has this. There is a loose connector with two wires and an end cap, but the end cap does not short the two connectors and so the shorting bar already was removed, or it is something else. It is "removing" the connector that retards the timing 3 degrees right? But my Haynes manual for up to '94 Aerostars shows an octane bar in the distributor and the stock bar is 0 degrees, but you can order 3 degree and 6 degree bars. However, not sure it is easy to change. Wonder if the 3 degree is shorter than the 0 degree. If so, maybe could unscrew the part outside the distributor and put a shim in to pull it back some.
Last month I looked all over for this connector and yesterday I found it plain as day. So if my knock comes back (Aerostar 3.0, '92) I will pull out the bar.
BTW, I notice to check the timing you are supposed to disconnect the "In-Line Spout Connector." What is that?
Checking my '93 Manual, I see that there is a Pink (PK) wire that runs to and from the SPOUT connector.
SPOUT is the signal from the PCM to the Ignition Control Module which directs the ICM when to fire the coils. As noted above, there is an in-line connector, the "SPOUT Connector", that looks a lot like the Octane Adjust Shorting Bar. When the SPOUT Connector is pulled, the PCM defaults the ignition timing to 10* BTDC.
Thanks, My underhood sticker says to disconnect the spout before checking the ignition timing and that has to be done with the engine hot. Then is says timing should be 10 degrees, but if disconnecting the spout makes it 10 no matter what, then it seems pointless to check it.
Anyway, the connector I found looks like what is in your diagram above and I will compare it tonight to make sure. Regardless, if the knock comes back I will pull the "bar" or "spout" whichever it is and see what happens.
Well, it still pings, so I pulled the connector out from the thingy that looks like the octane shorting bar. It totally cured the knock. Absolutely no knock, but .... the thing has a shaky idle, not major, but within 20 or 30 rpms the needle will shake just like an old person with Parkenson's diease. I could live with that because it did not cause a rough idle, but the other problem was when I mat the pedal and wind it out in first gear it doesn't want to shift and acts like it is not running right, almost sputtering, and then will shift when I let up on the pedal.
My guess is it is the SPOUT connector, which defaults the thing to 10 degrees timing and that it is defaulting to 10 degrees across the board, which would cause it to sputter at high rpm because by then it likely is retarded 17 degrees or so if defaulting to 10. That also would explain the loss of pep.
Why no shift at high rpm? Presumably because it has a vacuum shift modulator and the severely retarded timing is affecting that. Anyway, I threw in the towel, put the connector back together, and topped it with 10 gals of 94 octane. Hopefully I can get away with 89 or 90, but that's the way it is going to be from now on.
