Hello to all, hope everyone is surviving this virus. I'm planning some upgrades this summer with the install of a new 400cu engine. And a fuel system upgrade for my fitech go street 400. Does anyone have any experience with the poly fuel tanks available for our trucks? The plan is a poly tank with a tanks inc fuel pump..and ditch the fitech command center.
thanks
Brent
thanks
Brent
I have a poly tank on my 79 Bronco. No more rust!
I also just installed the Holley Retro Fit in tank pump in it as well.
Holley recommended a stainless steel ring that goes inside around the 3 1/4" you drill for the pump. But I didnt get it. So far mine is fine.
I installed the pump kind of center but further back to try to miss my sending unit float..well..the float hits the pump. I had to turn the float to the outside to make it work what it can. It still hits my pump some.
