No luck with searching. Has anyone mounted a 2014 older cap on a 2015+ 6.5 bed? If you have could you post what truck it was designed for. I will use the cap approx. 6 times a year and won't be leaving it n the truck when it is not in use. I can't justify spending $2000+ on a new one. Thanks, Bill C
It won't work, the cabs and beds are completely different and the cab and bed line up differently. Do a Google search then look at images and you will see what I'm talking about.
Have a neighbor that has done this and it doesn't look too bad. He had to retrofit some wood supports on the bed to level it out and not sure what he did with the rear. I do know it leaks water badly.
