Momentary Push Button Switch Controls Mod
Old Apr 10, 2020 | 07:56 PM
alumizilla's Avatar
alumizilla
As part of another project, I needed some push button switches on the dashboard that would be in a convenient location, but out of the way so I wouldn't activate them accidentally like bumping them with my knee. There's a blank spot to the left of the steering column, and that's where I decided to locate them. When I removed the panel below the steering column, there happened to be a screw right below that location, so it enabled me to rig up a small push button panel without drilling. I hacked away at a 3" x 6" sheet of black anodized aluminum until I got something that looked like this:
This is what it looks like mounted to the left of the steering column (lower trim piece unclipped):
The bottom part doesn't have to be pretty, because the trim panel will cover it, like so:
For my switches, I decided to use Cherry MX black keyswitches, for several reasons:
- The push feel is nice
- LEDs can be added
- Any custom keycaps can be used
- The square shape is efficient for the space (I can squeeze in 8 buttons there)
- The circuit under control is at TTL levels
I mounted the Cherry switches to breakout boards and mounted them to the anodized aluminum sheet with nylon standoffs. I trimmed an adhesive felt pad to a smaller size than the keypad and stuck it to the back so that there wouldn't be any rattling or scratching of the truck panel. Here's what the result looks like:
Yeah, it looks hack-ish but the Doc Brown look is ok with me. This is sort of a trial run anyway, and I can clean it up later. I mounted the switches with the LEDs at the top so they would be more visible from above. I used a 5v source for the LEDs. Topped off with black translucent keycaps.
The resistor values that I used for the LEDs helped to dim the brightness of the LEDs so that it wouldn't be annoying at night. LEDs are entirely optional but I thought I'd wire them up just for fun. Night time view:
It probably wouldn't take a lot of effort to make a nicer version of this. There's ways to cover up the guts, but I'll leave that for later.
Parts used:
3" x 6" anodized aluminum sheet (Black) - inventables.com 24908-07
Cherry MX Black - amazon.com B07RSWRHR9 (x8)
Translucent Black Keycaps - amazon.com B00F10VSR8 (x2, I used the four arrow key keycaps, twice)
Cherry MX Switch Breakout - sparkfun.com BOB-13773 (x8)
M2 nylon standoffs and screws - ebay
Trimmable felt pad - hardware store
LEDs - assorted supply
Resistors - digikey.com RS112-KIT-ND (resistors should be 1/6W for clearance reasons)
Old Apr 10, 2020 | 08:19 PM
Section179's Avatar
Section179
You can’t post about mysterious doc-brown switches and not explain what they’re for. That’s just evil.
Old Apr 10, 2020 | 08:22 PM
seventyseven250's Avatar
seventyseven250
Which are for offensive and which are for defensive accessories? And do you have ejector seats on just the passenger, or the rear seating positions as well? I can think of so many uses for these.
sammie0126
Dec 18, 2020 02:36 AM
RMBC Freeride
Dec 30, 2017 03:38 PM
strokin'_tatsch
20
Feb 28, 2017 06:55 AM
Coastal68
Jan 8, 2016 02:11 PM
strokin'_tatsch
Feb 12, 2011 11:48 AM
