Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Cruise control buttons
Old Apr 9, 2020 | 07:12 PM
Jackbox's Avatar
Jackbox
New to the forum. I have a 99 F150. The on/off button for the cruise control broke and so I bought a replacement. Is there a way to replace this button without have to take apart the steering wheel? Thank you.
Old Apr 9, 2020 | 10:33 PM
2001F350dualwheel's Avatar
2001F350dualwheel
On my F250 I was able to just pop them off and replace them. This was the plastic part. The button itself still needs the removal of the steering wheel center part
Old Apr 10, 2020 | 05:44 AM
JWA's Avatar
JWA
You'd start by disconnecting the negative battery cable and walking away for about 15 minutes---this allows any stored electrical energy in the air bag modules to bleed off essentially disabling them for this task. Next remove the steering wheel air bag for clean access to the switches and their connection to the clock spring.
Reassemble everything, reconnect the battery cable and you should have VSC once again.
HTH
James Doty
19
Sep 19, 2018 01:55 PM
1986F-150
Nov 28, 2017 02:54 PM
ford9303
Apr 30, 2014 10:21 AM
packratF350
Electrical Systems/Wiring
May 15, 2004 01:31 PM
jeepin
Aug 17, 2003 08:13 PM
