I have a 6.0 deleted and tuned running 175/30 injectors from warren diesel the engine and injectors are new there is what sounds like a lope when you get out and listen to the exhaust the engine sounds fine and is still making power i replaced the icp sensor thinking it was that and still have same problem any ideas?
Sorry to say it again.
Post some readings. We haven't a clue based on what you gave on opening post. We can guess, but that'll cost you money. Guys will be glad to help, but need info to start.
it’s 4 inch from turbo back so instead of hearing just the turbo whistle it has a stutter to it ficm has good voltage injector pressure is good icp cycle is 20-30% but it’s not throwing codes
