I'm a proud new owner of a '63 Falcon van, however the van did not come with door lock keys, so new lock cylinders were ordered. I removed the old cylinder from the passenger side door to replace with the new one, but there seems to be something missing. There must be a linkage between the lock cylinder and the rod which moves up and down when raising and lowering the inside door lock stem. I checked Carpenter, CG & Macs but saw nothing like I'm describing. Any guidance would be appreciated. Thanks.
There's a "door latch operating lever" that attaches to the lock cylinder with a retainer. Neither part was supplied with the cylinder, were furnished by themselves.
Parts are the same for right and left front doors and were also used on some Passenger Cars.
C0DB-6421971-B .. Front Door Latch Operating Lever / Right/Left same / Obsolete
1960/63 Falcon/Comet // 1961/67 Econoline.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
----------------------------------------------------------------- C3UZ-89264A44-A .. Door Latch Cylinder Retainer / Right/Left same / Obsolete
1961/67 Econoline.
NOS PARTS LTD has 4.
GREEN SALES CO. in Cincinnati OH has 4 = 800-543-4959.
Any of the springs that hold the tail onto the lock? Or is that the second no. you posted for the retainer that sounds more like the clip that holds lock into the door.
