2004f150 screw power windows dont work
Old Apr 6, 2020 | 11:57 PM
kingbuzo's Avatar
kingbuzo
Trailering
I have no power at the fuse panel on either side of the 30 amp breaker....any ideas where togo from here? I will remove fuse panel and begin checking wire connections, but just thought i would ask, thank you
Old Apr 7, 2020 | 09:00 AM
redfishtd's Avatar
redfishtd
Is your key on ?
You have a accessory delay relay in front of that fuse .see if thats working
Old Apr 7, 2020 | 09:03 AM
kingbuzo's Avatar
kingbuzo
Trailering
Originally Posted by redfishtd
Is your key on ?
yes key on , i will replace relay and see what happens...thank you...didny know about that relay
Old Apr 8, 2020 | 09:23 AM
redfishtd's Avatar
redfishtd
Check pin 30 to see if 12vdc there, then check across coil to see if its getting signal to energize.That may tell you more.
Old Apr 8, 2020 | 07:34 PM
kingbuzo's Avatar
kingbuzo
Trailering
Yup...relay was toast...replaced it and all was good...thats wierd...i dont hink in my lifetime ...i have ever had to replace a relay like that...thank you for the help
bradshaw6243
1983 - 2012 Ranger & B-Series
Jul 2, 2011 04:56 PM
OD
Electrical Systems/Wiring
Nov 23, 2002 09:12 AM
73Custom
Aug 1, 2002 10:55 AM
