Sponsored by: Real Truck
6.4 fuel issue???
Old Apr 6, 2020 | 09:28 PM
nuggetsfanct's Avatar
nuggetsfanct
6.4 fuel issue???
So long story short if my trucks sits for longer than two hours I have to purge air out of the fuel from the Schrader valve on the fuel cooler. I have no exterior leaks and no fuel In oil, my observation after doing this 100 times is the fuel is feeding back to the tank. I believe the check valve is stuck open but I can’t get a straight answer online to where it’s at, is it in the tank return? Or is it in the Fuel conditioner on the frame?
Old Apr 7, 2020 | 01:12 AM
Distinguished Diesel's Avatar
Replace the fuel filter. The housing probably has a crack and loses its prime. See it all the time on the 4 F550 tow trucks I work on
Old Apr 7, 2020 | 05:32 AM
senix's Avatar
senix
might want to make sure you are using oem fuel filters too.
Old Apr 8, 2020 | 11:19 PM
nuggetsfanct
thanks, I’ll swap both out and see if that does the trick.
Nathan Cox
Feb 24, 2017 06:35 AM
lee00
Oct 8, 2015 08:45 AM
nico963
6.7L Power Stroke Diesel
Jul 25, 2015 08:02 AM
dmanshane
May 28, 2012 07:25 AM
