Guess what happened here...
Old Apr 6, 2020 | 05:46 PM
Work Truck Fanatic's Avatar
Work Truck Fanatic
This is not my doing. It was at an adjacent campsite. But this post is not about me being perfect and bashing someone else. I have had my share of mishaps. For instance, I once decoupled my trailer before chocking the tires. I almost sprung a stinky leak when the trailer slid back. Fortunately I was on relatively flat ground and the tongue jack's foot stayed on the block and kept the trailer from crashing to the ground.
Anybody else with a story to share?
Old Apr 6, 2020 | 07:30 PM
HRTKD's Avatar
HRTKD
Looks like they forgot to pull up the tongue jack. Good think they didn't make it to the pavement.
Instead of chalking your tires, you should chock them. My kids kids get pissed off when I use their chalk for chocks.
Old Apr 6, 2020 | 08:25 PM
seventyseven250's Avatar
seventyseven250
A good trick that kinds sorta helps with this, if you think you might forget to put your tongue jack up, is to use at least a few 2x4's under it. Then when you pull forward it'll slide off them and a) you'll feel it and investigate or b) it'll be a few inches higher and less likely to dig a trench. Also helpful if you camp in soft areas, or you if you don't like to run the tongue jack down so far because you are impatient.
Old Apr 6, 2020 | 08:29 PM
HRTKD's Avatar
HRTKD
That's a good tip. I don't think I've ever used my tongue jack without using a block of wood. But I never thought of the block as a safety measure.
Old Apr 7, 2020 | 07:07 AM
SpencerPJ's Avatar
SpencerPJ
I had a shady homemade tongue jack with a smaller boat, and driving on I-65 through Louisville, pin came out, dropped, and started dragging. Oh the sound, and oh the heartbeat...
Old Apr 7, 2020 | 09:41 AM
Work Truck Fanatic
Good catch! Don't know how I did that...
Old Apr 7, 2020 | 08:46 PM
Marten's Avatar
Marten
Smile
Looks to me like they did hit the pavement. Nice black spot right where the dirt meets the pavement.
Chalk/chock, that's because you typed it wrong, lol, SmileSmile
Old Apr 8, 2020 | 11:30 AM
EDC8008's Avatar
EDC8008
I wass setting up one night with my old prowler, the wife was puttering around inside and had not chocked my tires, set the jack on the block I normally used and disconnected from the truck and it rolled back and dropped off the block. Boy was the wife calling me all sorts of things that night.
Old Apr 8, 2020 | 11:48 AM
HRTKD's Avatar
HRTKD
LOL!
My experience with my first hitch kept me from making that mistake. I couldn't get the coupler to come off the ball unless I chocked the tires and let the truck move forward so the ball wasn't up against the coupler lock. It took me a while to figure that out. There was a lot of frustration and use of a crow bar until the light bulb finally went on over my head. I think the angle of the WDH head might have been part of the problem.
Old Apr 8, 2020 | 12:19 PM
EDC8008's Avatar
EDC8008
The RV park we went to in Houston had a very slight grade that looked level when we got there.
Old Apr 8, 2020 | 12:55 PM
HRTKD's Avatar
HRTKD
I'm sure you held off suggesting to your wife that she needed to go on a diet after what she just did to the trailer.
Old Apr 8, 2020 | 02:29 PM
seventyseven250
I've slid my trailer a couple of time early on. Once it was only a few feet away from causing real damage. I haven't forgotten to chock the tires for a while now (knock on wood)
Old Apr 8, 2020 | 05:15 PM
Work Truck Fanatic
@EDC8008 that is classic! I bet she still holds that against you every now and then. I cracked up imagining how that would feel when the floor of the RV comes out from underneath you
Old Apr 8, 2020 | 05:19 PM
HRTKD's Avatar
HRTKD
Hours later, I'm coming up with some better comebacks/responses. Yelling EARTHQUAKE might have worked.
Old Apr 8, 2020 | 10:01 PM
jkhuntin's Avatar
jkhuntin
Husband to Wife: Honey, if you had just chocked the tires like you were supposed to this wouldn't have happened!!!!!!
And that's when the fight started!!!
jk
