Modular V10 (6.8l)
stuck plugs
Old Apr 5, 2020 | 08:51 PM
AA 6.8l's Avatar
AA 6.8l
stuck plugs
My V10 has two plugs that are stuck in the heads. The nut actually twisted off the top of the plugs. All of the threads of the plugs are still stuck in the head. One of the two now has a straight fluted easy-out broke off in it. Any suggestions would be appreciated. Thanks
Old Apr 6, 2020 | 01:39 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Ugg... Sounds like head removal and bringing it to a machine shop...
Hard to imagine steel plugs being so stuck in an aluminum head...
Old Apr 6, 2020 | 04:21 PM
trz1000's Avatar
trz1000
Luckily I haven't done it but there are removal tools and thread repair kits available. Some folks have been able to fix without pulling the head. Google will give you all sorts of hits on kits and tools.
Old Apr 7, 2020 | 11:51 AM
Sancho's Avatar
Sancho
Any progress? Sometimes, you can find it on YouTube. If you can, try an oxy acetylene torch, with the smallest tip. Heat the steel until it's red. Good luck.
Old Apr 8, 2020 | 06:24 PM
Veltech's Avatar
Veltech
I had 7 break when I did my plug change. Some broke clean in 2, others just the threaded part came out. The ones that the nut screwed off I used pliers and broke off top and then used a lisle kit 65600.
warren3527
1997 - 2003 F150
Jun 22, 2009 06:26 PM
davisenvy
33
Sep 28, 2007 10:40 AM
Packrat Super duty
Sep 26, 2007 04:55 PM
Rodney Taylor
Jan 5, 2004 10:17 AM
kevinken
Mar 31, 2003 11:49 AM
