1957-1960 4x4 count
Old Apr 5, 2020 | 04:35 PM
Red60's Avatar
Red60
1957-1960 4x4 count
Hoping to get a headcount here at FTE of how many fridge 4x4’s we have operational among us! Please join in and tell us what you have, if it’s factory or converted, pics, and technical details (F100/F250/F350 etc).
I will start with my 1960 F100 4x4 long bed. 292 two barrel 4wd from the factory.
My current project is 1960 F250 4x4 from the factory with 292 2barrel. This one is getting a 11:1 302 with 289 racing heads. 4 speed. Keeping all the original mounting points and wiring in tact so it could go back to stock if desired.
Old Apr 5, 2020 | 04:53 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1959/60 F100/250: The MODEL code stamped on the Rating Plate defines 2WD & 4WD
The first 3 digits of the VIN (series code: F10 or F25) only decodes to F100 or F250.
Old Apr 5, 2020 | 05:04 PM
Red60's Avatar
Red60
Good point for those who suspect theirs is factory. This is coded out on the data plate (in my case glove box door)
BMC
Old Apr 5, 2020 | 06:21 PM
NumberDummy
Upper: F25 = F250 // F253 = 1960 F250 4WD - 7400 lbs. Gross Vehicle Weight Rating.
Lower: F10 = F100 // F103 = 1960 F100 4WD - 5600 lbs. Gross Vehicle Weight Rating.
Some people that are unaware...that own 1959/60 4WD's see the series code of F10 or F250, assume their trucks were originally 2WD
Not so...
Old Apr 8, 2020 | 11:38 AM
Byrd.Dog's Avatar
Byrd.Dog
Here's mine. 1960 F250 factory 4x4 currently wearing a 59 chrome grill
Old Apr 8, 2020 | 12:16 PM
Red60's Avatar
Red60
The current count for this thread is:
1-F100
3-F250
I expect F100’s to outstrip the F250’s in the final counts.
BMC
Old Apr 12, 2020 | 10:33 PM
kujo3692's Avatar
kujo3692
Here’s my 59 F-100, original 4WD. Newer axles, original Sp
icer T-case
Old Apr 13, 2020 | 08:39 AM
Red60's Avatar
Red60
icer T-case
Your truck has that monster truck feel like Bigfoot! Does it have a lift on it for tire clearance?
current thread count
2-F100 4x4
3-F250 4x4
BMC
Old Apr 20, 2020 | 08:32 AM
grapp's Avatar
grapp
Count me in
Orig 60 f100. Had a 223 six will be getting a 390 shortly. This is a non custom cab model.
Old Apr 20, 2020 | 09:46 AM
Red60's Avatar
Red60
Now we are even stephen. Do you know if yours is conversion or factory? The data plate on the inside of the glovebox door will reveal that once decoded (see example above).
3-F100 4x4
3-F250 4x4
BMC
Old Apr 20, 2020 | 10:00 AM
grapp's Avatar
grapp
It's definitely factory... is your red one lifted at all?, Mine is sitting on LT30'sx9 because I kept the stock rims. Your truck looks like it sits a bit higher.
Greg
Old Apr 20, 2020 | 02:34 PM
Red60's Avatar
Red60
Greg
I think the previous owner put 1
ton springs in front and helper springs in rear.
BMC
Old Apr 20, 2020 | 03:37 PM
Byrd.Dog's Avatar
Byrd.Dog
Did anyone else's 3/4 ton come from the factory with 17" split rims? I still have mine with 7.50 x 17 bias ply mud tires stored in a barn. Can't find any tire shops in town that will work on them anymore, so I upgraded to 16" radials.
Old Apr 20, 2020 | 07:12 PM
Red60's Avatar
Red60
The stock wheels are long gone. It has aftermarket Mojock wheels. Maybe because of the tire shop woes.
BMC
Old Apr 21, 2020 | 10:34 PM
GeeeMCeee's Avatar
GeeeMCeee
Before and after, my 59 when I bought it, two years later after lowering it about 6”. Started as an F100 not sure what you would call it now. Replaced both axles, 79 Dana 44 in front 93 F350 LS rear 4.10. 7.3 diesel, ZF5 trans and I think 208 transfer case from 88 F250.
