i have a 95 F150 4x4 x-cab i am looking to put a locker on my truck yet do not have much money to spend. i am a construction supervisor so i can play in the mud all day going from house to house in my development ( no roads yet) but don't want to get stuck (keep the bosses from knowing i'm playing) What would anone recomend inexpensive not just cheap
thanks
A spool would be cheapest, but you would have to be running at least 36" tires to be able to drive it on the street. Other than that, check ebay or the ez locker or trac lock.
Originally posted by MUDN69 how about posi rear; spool up front? how do spools work in your front axle?
Very bad if you like to be able to turn in 4X4. The truck will have a bad tendancy to go straight on any slick surface and the steering effort will be increased.
I drove a Jeep with a spooled front and it wouldn't go around corners at all in the mud and when you stomp the gas it would tear the wheel out of your hands.
lock rite is pretty easy, but you need to follow the directions to the tee. It won't be that cheap, but it will be good, and you won't tear stuff up like a spool will.
