Need help with diagnosis
Old Apr 1, 2020 | 04:30 PM
TooManyToys.'s Avatar
TooManyToys.
From the dealers perspective, the labor to do piecemeal adds up to a mind numbing number. It depends if the failure is a singular failure or caused by a distributed cause, like low fuel pressure. So while an IDS check may show a fault, a secondary diagnosis is often warranted.
See my attached manifesto below.
Old Apr 1, 2020 | 08:13 PM
2112's Avatar
2112
Curious, what is the current cost to have injectors replaced?
Old Apr 1, 2020 | 09:40 PM
xcrsp440's Avatar
xcrsp440
You can purchase Motorcraft injectors from Autonation white bear lake for about $180 apiece.
If you have someone do it make sure they use Motorcraft Ford remans. Others seems to have less reliable outcomes.
Old Apr 1, 2020 | 11:46 PM
2112's Avatar
2112
Are the White Bear injectors ($180/unit) also remanufactured ?
Old Apr 2, 2020 | 07:38 AM
xcrsp440's Avatar
xcrsp440
Any injector you get from a ford dealer is remanufactured. Done by Ford (or their assignee).
mikeysfun
Jan 29, 2015 08:27 PM
shivaskeeper
Nov 29, 2013 11:28 PM
ddetrick78
Dec 3, 2012 06:25 AM
domwri
Jan 2, 2012 12:33 PM
tonefordays
Nov 2, 2011 06:48 PM
