Good motor swaps
Old Mar 30, 2020 | 10:12 AM
Cole_Manzoni's Avatar
Cole_Manzoni
Good motor swaps
Ok so my belt tensioner bolt broke off in the block mid drive and I had to drive a little less than a mile to get to a safe spot (in my head I thought “oh damn old truck power steering pump broke”) but it turns out my belt flew off and I got my truck really hot. Idk if I really broke it or not but just in case I did what motor and transmission combos will more or less bolt into my 1996 2wd f150 with the 5.0 that I can get a bit more horses from?
Old Mar 30, 2020 | 11:40 AM
sandymane's Avatar
sandymane
See if it will run. If you haven't replaced the belt yet, In it's condition you can still try to start it and see how it sounds. Of course you want to turn if off after it has run for less than a minute. Talking about replacing the trans and motor for more horses is putting the cart before the horse. Sandy
Old Mar 30, 2020 | 11:48 AM
Cole_Manzoni
True dat
but I’m gonna swap it eventually I was just planning on doing all the suspension and stuff first
Old Mar 30, 2020 | 11:55 AM
sandymane's Avatar
sandymane
If you locked the motor up from overheating, now would be the time to replace it or rebuild it if you haven't done a lot of damage.
Old Mar 30, 2020 | 01:15 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
If every person ever who popped a belt decided to swap their engine then this forum would be WAY more busy with motor swap threads. Go get a new belt, see if the truck runs. If it does, cool story bro, save up for your fantasy swap. If it doesn't then figure out WHY and if repairable, do that or if not then do your swap.
Old Mar 30, 2020 | 05:18 PM
Exwhyze's Avatar
Exwhyze
Yeah if I were you buddy I would try putting on a new belt tensioner and getting your parts hauler moving for your suspension and motor swap plan. You don't want to be sitting on a truck that doesn't move while trying to plan out moving something heavy.
Keg1973
Apr 13, 2015 07:11 PM
huttone
16
May 6, 2013 07:05 PM
tiopet
Apr 2, 2013 01:20 PM
jiveturkey692000
Sep 15, 2012 11:43 PM
Mike Roma
Oct 5, 2003 07:26 PM
