I posted this somewhere else on here, I forget where. The problem is in 1980 they only had one power feed to the switch to feed the headlights and the marker lights. They may have done this also in the late 70's trucks, not sure on that but the 1980 models have some small things common with the 1979 down trucks. In 1981 they added a pin on the headlight switch and fed the marker lights separately. The marker lights in the 1981-up trucks have their own fuse in the fuse box, and their own dedicated wire going to the extra pin on the headlight switch. That is the difference.
The 80 model year head light switch was a faulty design from the get go, the Panthers (possible others did as well) got the same design switch for 79 and 80 .. It was redesigned in 81 with an entirely new part and wiring changes so the original design switch could not be retrofitted. IIRC These switches were recalled (voluntarily by Ford) and replaced with a revised part that was less prone to failure.
Installed relays for hi/low beams last night so far so good, I'll still need to install original switch, but was a big difference just installing relays, dash lights didn't flicker,or dim when accelerated.
