Headlight switch
Old Mar 29, 2020 | 10:23 PM
Loosearro's Avatar
Loosearro
Trailering
Headlight switch
I noticed that my old switch has 7 pins and the new one has 8 pins, on 1980 f150 4.9 i6, question is why and will the 8 pin work in the long run
Old Mar 30, 2020 | 12:52 PM
Loosearro's Avatar
Loosearro
Trailering
does anyone know of this ,also there is no badge wire on plug connected to light switch
Old Mar 30, 2020 | 02:55 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I noticed that my old switch has 7 pins and the new one has 8 pins, on 1980 F150. Question is why and will the 8 pin work in the long run
You bought or the parts cluck sold you the wrong switch.
1980 F100/350 & Bronco switch is 1980 only = EOTZ-11654-A (Motorcraft SW-1560) / Marked: E0TB-11654-AA
1981/86 F100/350 & Bronco switch is different: E1TZ-11654-A (Motorcraft SW-1663).
Note: This is the wrong forum to ask questions. You want the 1980/86 F100 and larger truck forum.
Old Mar 30, 2020 | 08:28 PM
donjamer's Avatar
donjamer
Moved to appropriate forum
Old Mar 30, 2020 | 10:43 PM
Loosearro's Avatar
Loosearro
Trailering
mine says EITB-11654-AA
Old Mar 31, 2020 | 03:02 AM
ctubutis's Avatar
ctubutis
Which is for 1981-86 models, you need one for the 1980 variant - a one-year-wonder concerning wiring.
Old Mar 31, 2020 | 07:26 AM
Loosearro's Avatar
Loosearro
Trailering
Headlight switch 7 pin
Sorry for got to mention it is a Ranger/ Explorer
Old Mar 31, 2020 | 07:32 AM
NumberDummy
Doesn't make a bit of difference what model it is. Only the year makes a difference.
1980 uses a different headlamp switch than 1981/86. If your switch is marked E1TB-11654-AA this is a 1981/86 switch.
Old Apr 2, 2020 | 09:47 AM
1986F150six's Avatar
1986F150six
Thanks to the information provided by Mr. NumberDummy, this was located on eBay:
https://www.ebay.com/itm/Headlight-S...ss!40475!US!-1
Old Apr 2, 2020 | 03:02 PM
Franklin2's Avatar
Franklin2
I posted this somewhere else on here, I forget where. The problem is in 1980 they only had one power feed to the switch to feed the headlights and the marker lights. They may have done this also in the late 70's trucks, not sure on that but the 1980 models have some small things common with the 1979 down trucks. In 1981 they added a pin on the headlight switch and fed the marker lights separately. The marker lights in the 1981-up trucks have their own fuse in the fuse box, and their own dedicated wire going to the extra pin on the headlight switch. That is the difference.
Old Apr 2, 2020 | 05:35 PM
matthewq4b's Avatar
matthewq4b
The 80 model year head light switch was a faulty design from the get go, the Panthers (possible others did as well) got the same design switch for 79 and 80 .. It was redesigned in 81 with an entirely new part and wiring changes so the original design switch could not be retrofitted. IIRC These switches were recalled (voluntarily by Ford) and replaced with a revised part that was less prone to failure.
Old Apr 2, 2020 | 06:20 PM
Loosearro's Avatar
Loosearro
Trailering
Wow good info to know,wondering what else I'm going to run into. Everyone that has answered me I really really thank you all.
Old Jul 26, 2020 | 05:45 PM
Loosearro's Avatar
Loosearro
Trailering
Installed relays for hi/low beams last night so far so good, I'll still need to install original switch, but was a big difference just installing relays, dash lights didn't flicker,or dim when accelerated.
Pipejay
New Member Introductions
Aug 8, 2018 08:43 AM
omni
17
Jan 12, 2006 10:38 PM
woogs
Dec 18, 2005 01:36 PM
TallPaul
18
Aug 20, 2003 07:29 AM
