Tailgate Hitting the Coupler
Old Mar 29, 2020 | 11:20 AM
PENOBSCOT's Avatar
PENOBSCOT
Out of curiosity, what are you guys doing if anything about the the tailgate hitting the trailer coupler? I just set up my WD hitch and the trailer is 1/2" down in the front from level. With it set up this way the tailgate hits the coupler when its down. As of right now my only option would be to lower the ball mount down one hole on the shank so that the tailgate doesn't hit.
Old Mar 29, 2020 | 01:01 PM
meborder's Avatar
meborder
If you do that, the trailer will be very low in the nose which can cause some serious handling issues.
Not a lot you can do.
1: you can lower the nose then use blocks between the axles and springs to lower the trailer the same amount so that it stays level.
2: put a body lift on the truck
3: deal with it the way it is and just don’t lower the tail gate when you are hooked up.
4: get a vehicle without a tailgate (large SUV)
slim pickin’s for options.
maybe I’m missing something?
Old Mar 30, 2020 | 09:31 AM
HRTKD's Avatar
HRTKD
I use option 3 above. But there is another option:
4. Use an extended length ball mount to put the trailer further away from the truck.
I think it's a lousy option and I wouldn't waste _my_ time pursuing it.
Old Mar 30, 2020 | 11:06 AM
Theboneskes's Avatar
Theboneskes
DONT use an extender with a WDH! Your trailer when connected to your trailer should be level. Adjust the hitch so its level. If your tailgate hits the ball mount your SOL... dont have a fix for it, since I drive an Excursion. But the trailer is supposed to be level.
Old Apr 2, 2020 | 04:43 PM
Bugzilla46310's Avatar
Bugzilla46310
The trailer coupler is what goes on the ball. I doubt your tailgate is hitting that. It could be hitting the trailer jack. After you slam your tailgate into it 3 or 4 times, you will remember its there and won’t do that anymore. Only then fix the dent in your tailgate.
Old Apr 2, 2020 | 04:49 PM
HRTKD's Avatar
HRTKD
If the ball mount is really high then I could see the coupler hitting the tailgate. But I agree, experience is a great tutor.
Old Apr 2, 2020 | 07:31 PM
meborder's Avatar
meborder
the tailgate Of most pickups would hit the trailer coupler on my camper. The tongue is stupid high.
The hitch on my expedition is about 4” higher than most pickups and I have the ball raised up 3” from that to account for squat.
measure up from your hitch 7 inches ... I bet you are well into the tailgate.
Old Apr 2, 2020 | 10:43 PM
Theboneskes
A squat of 3" ? What are you hauling with that much tongue weight? I had a 2003 Expedition without air ride so I know how they are... But 3" ? Sure you don't need a WDH, or load a little more weight on the back of your trailer?
Old Apr 3, 2020 | 06:13 AM
Bugzilla46310
Pictures would be nice.
Old Apr 3, 2020 | 04:40 PM
LabCab's Avatar
LabCab
I have a 2019 F350 DRW with the rear view camera and just bought a 2019 Artic Fox 32A bumper pull travel trailer. Due to the way Ford designed the tailgate to accommodate the darn step it flares out and will hit the coupler/ball when the tailgate is lowered.... It is something that I am not happy about, but can work around it to have a great truck and trailer....
Old Apr 3, 2020 | 04:43 PM
ford390gashog's Avatar
ford390gashog
You won't even get enough squat to need a WDH on your truck.
Old Apr 3, 2020 | 08:22 PM
meborder's Avatar
meborder
it doesn’t squat 3”. Probably more around 2” with the WDH hooked up.
the problem I was trying to illustrate is that the top of the coupler needs to be above the top of the receiver which is already 4” higher than it would be on most pickups.
as for me, my tongue weight was 1080 when I measured it on the scale. With the WDH hooked up I was returning a few pounds more than 100% of the empty weight to the front axle. I should go out and get some measurements that would help illustrate what I’m talking about.
this is a pic of my old truck on its last trip hauling the camper. Notice how the top of the ball is above the receiver by at least 2”. The tongue on this camper is really high. If not for the already very tall receiver on the expedition (in the bumper) it would be well into the tailgates of many pickups because it would have to be 6+ inches above the top of the receiver hitch. The tongue on the trailer is at the same height as the camper frame, not below it like many are. If the OP is like mine, I can see how it would be a problem.
Old Apr 11, 2020 | 02:03 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Maybe PENOBSCOT will come back with a picture of the problem. Until then, we're speculating.
Old Apr 11, 2020 | 01:36 PM
longhaultransport's Avatar
longhaultransport
If you are really close, you could change the ball out to one without the built in rise.
Old May 27, 2020 | 03:44 PM
OxfordWhite's Avatar
OxfordWhite
Mike,
It is called one person, one vote. Not 1 acre, one vote.
