Vacuum lines?
Old Mar 27, 2020 | 06:05 PM
JohnKelly427's Avatar
JohnKelly427
Vacuum lines?
I have my 78 f150 4x4 (78 cab, 76 frame, motor, trans, etc) all apart, and I have a few questions about vacuum lines. It is a 390 with a 4 barrel holley 4160 on it. My questions are: the flap for air intake on the air cleaner cover, where is it supposed to be connected to? And also there is a vaccum suction device on the drivers side exhaust pipe right next to the manifold, first of all, what is it, and where is the vacuum tube supposed to go on that? I took a picture of that for ya's.
Old Mar 27, 2020 | 09:03 PM
72rtchallenger's Avatar
72rtchallenger
Originally Posted by vaccum suction device on the drivers side exhaust pipe right next to the manifold, first of all, what is it, and where is the vacuum tube supposed to go on that? I took a picture of that for ya's.
[img
https://cimg0.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/2000x1124/15853502622783099421182996494114_624dac35055ae4f0a cae9b9c190811743900f0fc.jpg[/img]
I believe in the picture its called a heat riser and are a bad design from what I remember , I alway kept them in open position an unhooked , you can google more information about how there suppose to work ,but I never like them
Old Mar 29, 2020 | 10:11 PM
83sd's Avatar
83sd
Delete both of them, but more importantly , Make sure the valve on the exhaust is not partially closed. I would take it out and gut the valve.
Old Mar 29, 2020 | 10:13 PM
83sd's Avatar
83sd
Delete both of them, but more importantly, Make sure the valve on the exhaust isn't stuck partially shut. I usually gut them.
79Ford100
Aug 29, 2019 04:15 PM
n4ynu1010
20
Feb 22, 2019 11:27 AM
caravaggio2000
Dec 24, 2018 08:10 AM
mmmmoore24
Jun 25, 2014 02:57 PM
pinkpantherbeekeeper
Feb 23, 2013 02:46 PM
