temperature sending unit
Old Mar 27, 2020 | 04:50 PM
49m47's Avatar
49m47
Greetings
I hope this finds everyone healthy in the difficult times.
My truck only has to run a few minutes and the gauge will read hot. I have Fluke 561IR Thermometer. Checking multiple places over the heads, hoses and radiator the hottest temp I read is 191 deg F. That doesn't seem to be hot enough for the gauge to read HOT (I could be wrong). At this point I'm thinking its the temperature sending units. They cost $45 each from Macs. I would like to have something more then " I think" before I spend $100 (plus shipping).
Thoughts?
Thanks
Old Mar 27, 2020 | 05:36 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Check the "excess heat switch" (the one with only one wire). The terminal should be grounded until about 212 degF. When it is open, the gauge will go to Hot. Try grounding the wire that goes to it, if the gauge behaves normally, that's your problem.
Ablaize
1983 - 2012 Ranger & B-Series
Jun 19, 2007 10:04 PM
areed1
Aug 7, 2006 09:40 AM
HiDesertRat
Dec 22, 2004 02:17 PM
gibhart
Feb 21, 2003 09:54 AM
mk
Apr 30, 2002 10:51 AM
