Mounting spacers
Old Mar 26, 2020 | 08:39 PM
LostFordTX's Avatar
LostFordTX
Mounting spacers
1974 F250,
FE 360, C6 Auto
Factory A/C
Ok, I had taken everything apart to have the motor machined. I've gotten mostly everything pit back on till today. I bought a new A/C system and they sent a new bracket to mount the compressor, I put everything together, no problems with pulleys. The bracket didn't work. So they sent an adapter plate to mount to the factory York bracket. Now, the fan pully is hitting the AC bracket. Anyone have any ideas on the sizes of the spacers that go behind all the components? I've obviously done it wrong. Pics would be great if someone had that also. Mainly the AC bracket and PS bracket. I think I have the wrong sizes on them causing them to stick out and hit the pully.
Old Mar 26, 2020 | 09:33 PM
1TonBasecamp's Avatar
1TonBasecamp
Pics would also be great from your end so we can see just what you're dealing with.
And a description of what you're using too please. You said you bought all new, but does that mean replacement original stuff, or all aftermarket? Sounds like an aftermarket setup, but if so which one are you talking about.
I'm not familiar enough with any of them to help yet. But pics would be helpful I'm sure.
Paul
Old Mar 26, 2020 | 10:26 PM
LostFordTX's Avatar
LostFordTX
1 ton
All the pulleys and brackets are OE. I cant remember where the spacers go exactly to ensure the pulleys line up correctly and have the spacing required to not interfere with anything else. That's where the question is based on the stock pulleys and spacers.
Old Mar 27, 2020 | 02:59 PM
1TonBasecamp
Ok. Can't help you directly then, since the brackets are (at least as I understand it) quite different between your '74 360 and my '79 400.
But my power steering did have a spacer, that I lost and then found, but that was awkward in lining up. Was basically about a 5/16" thick or so disc that mounted between the bracket and head.
My A/C compressor is the York type (now I see you have the same York and you said factory a/c in the first post. Sorry bout that) and sits on the top of everything, above the engine. I have four or five groove pulleys and everything gets it's own belt. Crazy busy up front there!
Hopefully someone who has the same setup as you will post up some pics of what's what.
Paul
Sam's1967
284
Mar 31, 2017 12:43 PM
Mdc9966
WTB - Parts & other
Sep 11, 2015 10:16 PM
V10man
Dec 18, 2013 06:52 PM
tfmech
Jul 14, 2012 11:54 AM
IICAP
Aug 21, 2008 12:53 AM
