swapping camshafts
Old Oct 15, 2003 | 09:43 AM
bong420's Avatar
bong420
swapping camshafts
i was curious to know if its possible to put like a ford motorsport B cam out of a mustang in my 95 f150? its got a roller 302 as far as i know and i figured it would swap with no problems, am i correct or would this cause some problems? and i was also wondering if anyone knew if they make an air intake for my truck?havent found one yet but thought i would ask! thanks
Old Oct 15, 2003 | 12:37 PM
jwtaylor's Avatar
jwtaylor
the cam will work and given you have roller lifter you could probably get away with reusing them. unless someone is gonna give you the cam, just call summit or jegs or comp cam or crane and let them pick you out a cam that way you will be even more impressed with the end result as opposed to putting a cam that was intended for a car in your truck. Just a thought and good luck, let us know how it goes and weather or not your happy with the gains.
Old Oct 15, 2003 | 01:32 PM
bluestang65's Avatar
bluestang65
Trash your airbox in favor of a conical K&N and put some pipe from the hardware store on. The only obsticle to overcome is the presence of two mouths to feed on the throttle body. With a little creativity and patience you can not only save some money, but have a little satisfaction. Besides, who wants to pay 250.00 bucks for two dollars worth of plastic, a filter and some clamps.
