truck bed??
Old Oct 15, 2003 | 09:29 AM
824x4ride's Avatar
824x4ride
Question truck bed??
well i have an 82 f-150 short bed stepside now my wood bed floor and rails are pretty ate up could i replace it with a standard short bed that isnt a step side to get away from the wood flooring? everything should bolt up right?...thanks for the help
Old Oct 16, 2003 | 07:57 PM
lastchance's Avatar
lastchance
I can tell you for absolutely sure...it will! I took a wrecked and twisted up 84 stepside frame and made a utility trailer out of it. Took off the good stepside bed and bolted on an old standard shortbed bed in it's place. No drilling, went right in the same holes as the stepside. Try and get the wiring harness with the bed because it will just plug right in too. The only thing I'm not sure about is whether or not you'll be able to use the stepside bumper...I didn't put a bumper on my trailer and I think it might hit the bottom edges of the bed.
Old Oct 16, 2003 | 10:43 PM
84ford460's Avatar
84ford460
Stepside bumper wouldn't give you much protection on the styleside bed. I would suggest getting a step bumper for the new bed.
Just my opinion.
Have a good one!
Larry
1984 F250 4x4 w/460
Old Oct 17, 2003 | 08:22 AM
824x4ride's Avatar
824x4ride
appreciate the info i have a home made bumper with a drop hitch on it so if it gives me any trouble ill just make a new one...thanks
Old Oct 17, 2003 | 12:58 PM
Txquadhunter24's Avatar
Txquadhunter24
If you want to keep the Flareside look of your truck, Do like some do and Replace the wood with a steel sheet or Diamond Plated sheet. Then just weld or Tack weld it into place. You could also find a Flareside bed from 87 to 95 to replace it with they have a soild metal floor and styleside type locking tailgate instead of the chains. Just and Idea for ya.
