starter removel
starter removel
Hi need to know if there is any tricks to remove athe starter on 92 4.0all wheel drive got the twwo bolts out and diconnect front wheel drive line but there is not much room does the starter come out the bottom thanks bruce
Yep, the AWD version is a bugger to get the starter out of. You have to disconnect the driveshaft from the front differential and push it as far as possible out of the way. Even then, there is just barely enough room to get the starter out by tipping it up on end.
