Sponsored by: Real Truck
Vibration
Old Mar 20, 2020 | 09:20 PM
Timfern's Avatar
Timfern
Vibration
I am new and have a 2006 F350 crew cab long box dually 6.0. When I have weight in the back with 100 gal tank and tool boxes I don’t have much of a vibration but when tank is empty and no weight in back the vibration going down the road if felt in the seat and in steering wheel. I just had the front end done (ball joints tie rods etc) U joints are tight but vibration getting worse. With the air bags pumped up it takes little bit away. Sometimes I think it’s motor related but unless a injector is going out to cause it no clue. Those were done just over year ago. Any help be appreciated. Thanks Tim
Old Mar 20, 2020 | 11:11 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
It's really really hard to get the rear tires balanced so there is no vibration on a DRW when empty. The set of tires I have on my 2013 were a problem until I removed all the weights and added 5oz of balancing beads in all the tires. Now I have a smoth ride
Denny
Old Mar 20, 2020 | 11:24 PM
Timfern's Avatar
Timfern
Maybe I’ll pull them off tomorrow and see if I can find place open to get beads and give it try. Cheap to do when you have a tire machine at the shop. Thanks!
Old Mar 20, 2020 | 11:32 PM
rvpuller's Avatar
rvpuller
Be sure and remove all the weights. I bought my beads on Amazon.
Denny
Old Mar 21, 2020 | 12:50 PM
redford's Avatar
redford
FTE Leadership Emeritus
I'd also check your U-joints. A little weight causes a bit of suspension squat, changing the drive shaft angle, which eliminated the vibration.
Old Mar 22, 2020 | 11:27 AM
SuperDutyScaler's Avatar
SuperDutyScaler
My 04 F350 srw has a highway vibration for like TEN years now. I gave up trying to find it a long time ago
Bucky3d
May 24, 2010 09:38 AM
superduty4x4
Apr 21, 2008 08:46 AM
icunurse2007
1997 - 2003 F150
Mar 23, 2008 02:28 PM
slickwillie
Mar 21, 2005 09:11 AM
