2020-2022 Super Duty FORScan Spreadsheet
#1096
I got in my truck tonight and was pleasantly surprised to see the Ford performance splash screen come up briefly, followed by the Lincoln Sync 3 theme. However when I shut the truck off there was no exit screen, just a black screen. As much as I like the Ford performance splash screen I'm willing to give it up to get the Lincoln theme for the Sync 3 ..... I'm just not a fan of all the blue in the Ford theme.
#1097
#1098
#1099
On the 2020-2021 Superduty Spreadsheet I found that the notation on Power Fold mirrors is incorrect.
Adding the 8 gives you mirrors that fold/unfold with lock/unlock - Effectively does the same thing that selecting autofold in the dash menu does - Spreadsheet says this gives you Lincoln Style Mirrors, which is not correct.
Adding the 84 gives you Lincoln style autofold mirrors that fold/unfold only when the driver's door is opened. - - Spreadsheet says this gives you Lincoln Style Mirrors that unfold only when the truck is started, which is not correct.
Please update, thanks for the great resource!!
#1101
ZooDad
#1103
After reading that folks are having luck changing tire size - relearning the TCM/PCM to clear code and all good. Well, found a ####mm setting that got the 285/75R18 spot on. I did the clear Transmission tables, reset TCM and reset PCM but I still get the gear wrench. I want to be sure that resetting the modules = relearning the module?? If not....maybe I just need to do that. If not, I can swing by the dealer (good relationship) to see if they can program for me.
Thanks for any help.
jjw
ND
jjw
ND
#1104
#1105
Just wanted to double check I had my Titan tank put in Wednesday and changed the main value in the spreadsheet for the 55 gallon value for the IPC but I also see there is a value for the PCM that says same value as IPC. Did I need to change the PCM value as well? After a key cycle in a full tank I showed 843 miles till empty and it is dropping in what looks like in an appropriate amount? Thank you
#1107
#1108
Wireless Android Auto
Wireless Android Auto.
Not 'zactly SYNC related, but of interest nonetheless...
https://www.autoevolution.com/news/h...rs-157414.html
https://www.aawireless.info
Your phone options must have an "intelligent switch to mobile data when Wi-Fi internet is slow or unstable" (Samsung-speak) as the dongle connects to the phone by Wi-Fi, not BT.
