302 V8 Performance??? Help
Old Feb 20, 2001 | 12:46 PM
PAUL_2's Avatar
PAUL_2
Old Feb 20, 2001 | 08:04 PM
reddevilf150's Avatar
reddevilf150
Can anyone tell me what kind of horsepower and torque a 1995 F-150 302 V8 has? I'm just trying to find out what I am dealing with here. And can anyone help on what I could to raise to horsepower and to at least 300hp, while also increasing the torque. Thanks for the help.
RedDevilF150
Old Feb 20, 2001 | 11:24 PM
KevinT's Avatar
KevinT
stock is 210 hp and 275 torque
to get 250 RWHP (rear wheel) out of mine I did the following:
ported and polished the upper/lower intakes and the heads, pretty easy, summit sells a kit that works with a dremal tool, and the directions were pretty straight forward, that by seat of the pants did a big difference, but not as much as I wanted, then I purchased a throttle body spacer, helped with lower rpm power, then it was time for the K&N FIPK intake, that didn't do anything except make a cool sucking sound at high rpm's, after doing all of the intake work I had a lean condition that would cause popping out of the exhuast, annoyed me enough to get an adjustable fuel regulator and larger injectors, solved the popping and I got even more power especially at high rpms (high rpms to me is over 3500, I dont go more than 4500 due to the fact my truck has 118k miles...floating a valve spring is not a cool thing) Basically to get power out of a 5.0 its not hard, just plan out what you want to do and there is TONS of stuff that can be done, oh my 250 RWHP? Its a fact, I had the beast dyno'd this past weekend...hp peak at 4200 and 310 ft/pds of torque at 3500 rpm
1995 F-150XL SC/SB
http://members.sounddomain.com/blind
5-Star Rated F-150 (Big Stereo)
