Looking for a drivers side matching mirror head for my 78 F100. Just need the mirror head and not the bracket.
D8TZ-17723-A .. Mirror Head - 6" x 9" Stainless - Right/Left is the same - Mirror head mounts directly to plate, does not use a gasket / Obsolete
Use with TYPE 9 low mount swing lock mirror - 1978/79 F100/350, Econoline & Bronco.
No Ford dealer or obsolete parts vendor has any.
Note: There's a 1979 6 x 9 mirror head (D9TZ-17723-A) that uses a gasket (glass in mirror head is mounted in black rubber gasket). No one has this mirror head either.
There are other 1973/77 mirror heads that look similar, but measure 5 1/4" x 8 1/4."
