Back Glass Replacement
Old Mar 18, 2020 | 01:46 PM
lewiscrouse's Avatar
lewiscrouse
Hey guys. Had my back glass get destroyed the other day and I've been trying to find a place that'll cut me a new one. Does anyone have a template? I need one to send to the glass cutter.
Old Mar 18, 2020 | 02:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by lewiscrouse
Hey guys. Had my rear windshield get destroyed the other day and I've been trying to find a place that'll cut me a new one. Does anyone have a template for the rear windshield?
Known as the rear window aka back glass. The windshield is at the front.
Same: 1961/66 F100/1100 // 1963/69 N/NT500/1100 // 1967/69 F800/1000
Old Mar 18, 2020 | 03:38 PM
robertrpeak's Avatar
robertrpeak
Not according to Safelite!! https://www.safelite.com/windshield-...ear-windshield
Old Mar 18, 2020 | 03:55 PM
NumberDummy
Originally Posted by robertrpeak
It's been called the rear window glass or the back glass for over 100 years.
Old Mar 18, 2020 | 04:09 PM
lewiscrouse
I'd accept my ignorance rather than say Safelite has it right
Old Mar 19, 2020 | 05:03 AM
Crop Duster's Avatar
Crop Duster
The original glass in all the flat windows was tempered glass. Tempered glass cannot be cut. It must be cut first then tempered. If you attempt to cut tempered glass it will explode into lots of little pieces. You can get the rear glass from e-bay, probably for less money than at a glass shop. https://www.ebay.com/itm/1961-1962-1...MAAOxydlFS3ZKu
Old Mar 19, 2020 | 07:33 AM
robertrpeak
Didn't say it wasn't, just not everyone uses the same terminology these days, so your right, he's right. Live with it....
Old Mar 19, 2020 | 09:00 AM
6t6merc's Avatar
6t6merc
I took a apart a door recently to remove the good window it contained. I found something I had never seen - the window was untempered, laminated glass, like windshield material but flat. Not too safe, so it went to the landfill.
Old Mar 19, 2020 | 11:06 AM
lewiscrouse
Thanks CD, I guess my rear window wasn't tempered then given the way it fell apart on me after it had been cracked. Fell apart into 1000 little pieces into my cab. I'm a little wary of buying that off of ebay just because I can't tell what the dimensions are. It looks wrong to my eye, but that could just be the picture.
6t6merc, how could you tell?
Old Mar 19, 2020 | 11:20 AM
AZ66F100's Avatar
AZ66F100
T Fell apart into 1000 little pieces into my cab.
That's what tempered glass does.
Old Mar 19, 2020 | 11:55 AM
Crop Duster
The ones on e-bay fit perfect with one small difference. The original Ford glass was .210 thick all the replacement glass is made mostly in Thialand and is 6MM, .240 thick. But it fits just fine. And as in the previous post tempered glass by design shatters into small pieces so there aren't any big shards of glass flying around in a wreck. The safety glass that 6t6merc referred to is two thin sheets of glass with a flexible plastic laminated in between them. It is only used in windshields now because a single thickness tempered glass windshield would suck if it got hit by a rock and exploded in your face.
Old Mar 19, 2020 | 12:13 PM
lewiscrouse
Wow I'm an idiot, read that wrong. Thanks guys. I'll see about getting one of those.
81oneton400
22
Jun 15, 2012 08:10 AM
montgoml
2004 - 2008 F150
Jul 31, 2011 09:50 PM
greenhornet410
2004 - 2008 F150
Jun 2, 2009 11:01 AM
Johnny Langton
Jul 8, 2008 07:22 AM
FeHorse
Paint & Bodywork
Aug 9, 2001 05:42 PM
