Rear engine seal
Old Mar 18, 2020 | 08:39 AM
jdavidsmi's Avatar
jdavidsmi
Rear engine seal
The rear seal on my 302 has been leaking for a while and I’m tired of cleaning up the oil on the garage floor, and smelling the odors form where it drips on to the exhaust crossover pipe.
My question is, is it practical to replace the seal with the engine in the truck or just pull it out?
Old Mar 18, 2020 | 10:20 AM
kenny nunez's Avatar
kenny nunez
Seal leak
Are you sure the oil is leaking from the rear seal? Remove the cover from the front of the bell housing and check if oil is slinging off the flywheel. If not you may just have to replace the oil pan gasket. Also make sure the rear of the intake manifold is not leaking.
Old Mar 18, 2020 | 11:25 AM
matthewq4b's Avatar
matthewq4b
If yours is an 84 then you need to pull the tranny to do the rear main as it will be a one piece. As for pulling the engine or pulling the trans that depends on what you have available for facilities.
A shop will drop the trans. But it may be easier to pull the engine at home. if you do not have AC, then pulling the engine should be the easier IMHO.
Old Mar 18, 2020 | 12:52 PM
jackietreehorn's Avatar
jackietreehorn
If and only if it has a two-piece seal, then you can do it underneath the vehicle. Lots of cussing involved. If it's a one piece, then you must pull the engine and might as well totally reseal.
Old Mar 18, 2020 | 02:00 PM
Olds64's Avatar
Olds64
x2
If you reseal the entire motor you MAW run a hone in each of the cylinders and R/R the rings and bearings. It's a slippery slope.
Old Mar 18, 2020 | 09:03 PM
jdavidsmi's Avatar
jdavidsmi
I pulled the starter off and it sure looks to me it’s the seal, so I decided to pull the engine. It’s been a few years but I still have the transmission jack and engine hoist and stand. I have the seal and a new oil pan gasket
With the virus going around, I will not be going anywhere for a while, so the wife tells me. Now is a good time to get it done.
Old Mar 19, 2020 | 10:28 AM
kenny nunez
Oil leak
Since you have a manual transmission the thrust shoulder on the one of the main bearings should be worn so it would be a good time to replace the main bearings.
gtuttle
23
Jul 16, 2009 12:33 PM
xlt4wd90
Aerostar
69
Jun 28, 2006 07:05 AM
hster
18
Aug 27, 2004 08:07 PM
egf
Jun 2, 2004 07:08 PM
redhead
Feb 12, 2002 04:30 PM
