Sponsored by: Real Truck
Dually brake shield
Old Mar 18, 2020 | 08:38 AM
tddougla's Avatar
tddougla
Dually brake shield
Have what appears to be a brake shield mounted on the drivers side of my 1999 Ford F350 CrewCab Dually. Any thoughts on what it is and what it was intended for?
Old Mar 25, 2020 | 10:33 AM
SuperDutyScaler's Avatar
SuperDutyScaler
Early 99 trucks had the drivers side rear axle caliper mounted in front of the axle tube. Ford quickly figured out rocks etc would fly up and hit the caliper so they designed and recalled trucks so they could install this shield
Old Mar 25, 2020 | 11:20 AM
tddougla's Avatar
tddougla
Thanks much for the reply, makes perfect sense. Thought the passenger side one may have simply rusted off. Assume with the newer Fords they aligned the calipers so this was no longer an issue.
Old Mar 25, 2020 | 08:42 PM
WWR's Avatar
WWR
Looks to me like you hooked a piece of a small culvert
Old Mar 26, 2020 | 01:20 AM
SuperDutyScaler
2000 and on Ford put both calipers behind the axle where they should have been
MarkRogers
Oct 2, 2017 12:15 PM
L.TONY F350
Aug 8, 2006 04:56 PM
JFKF350
Jun 17, 2002 02:25 PM
