4x4 conversion
Old Oct 22, 2003 | 12:22 PM
Scot's Avatar
Scot
Measure it but I think that the axles will bolt to the springs front and rear.
The t/c crossmenber should also be the right width.
You will have to upgrade the steering sector. Seems like the '68 uses a parallel drag link sector like the '5X uses. Do a search and see, but straight axle people often use a Toyota 4x4 power steering sector. I do not know how big a tire it will turn.
You will have to fabricate a drag link to mate the sector and front axle.
I do not think a body lift will be necessary.
This is not going to be quick and easy but is do-able.
Old Oct 22, 2003 | 01:47 PM
1952's Avatar
1952
4x4 conversion
Grover;
Give me some info on the Marmon Herrington's in Deals on Wheels. Year, size, price, location? Please!
Old Oct 22, 2003 | 09:33 PM
csimmons's Avatar
csimmons
I just found an amazing truck. If you go to chuckstrucksllc.com He has a 1950 ford ranger. It's one of the most incretible trucks i have ever seen!!!
Old Nov 18, 2003 | 09:13 AM
hangman's Avatar
hangman
check out a ranger p/up extra cab chassis,frame widt.h close and the rear spring perches can be slid foword the 7 inches you need to match wheelbase. later models have 8.8 rear and advanced adapters has a kit{fairly cheap} to put in a 302.ride height with 30x9.50-15 about 4 inches higher than stock.did one with a friend about 5 years ago.remember ''anybody can restore a car,but it takes a real man to cut one up!'' if it;s not personalized than who wants it!!!
