Sponsored by: Auxito
Leveling kit 03 fx4
Old Oct 14, 2003 | 11:47 PM
racerbrown's Avatar
racerbrown
Leveling kit 03 fx4
I have a 2003 FX4 scab and i would like to lift the front to level it with the rear does any one make this kit? Thanks for all replies
Old Oct 15, 2003 | 08:34 AM
LxMan1's Avatar
LxMan1
Hi and welcome to FTE
No kit is needed, it has torsion bars that are adjustable. There should be an adjusting bolt at the rear of the bars that run back to the crossmember. Just tighten the bolts up until it is raised where you want it.
Make sure to have the alignment checked after you raise it.
Jimmy
Old Oct 15, 2003 | 10:27 AM
racerbrown's Avatar
racerbrown
Thanks I will check that out.
