Add-a-Leaf Suspension
Old Oct 14, 2003 | 11:46 PM
myst's Avatar
myst
I have a 03 fx4 and was wondering if the add-a-leaf suspension would raise the front end up enough to put 315's on 16x10 rims?? if not what is the max size i could run?
Old Oct 15, 2003 | 05:59 AM
user 708242442's Avatar
user 708242442
They also sell a leveling kit so you don't have to stiffen your ride with another leaf. Also my buddy has 315's on his but they rub once and awhile. I think specs say 305 is the biggest with no rubbing.
Old Oct 29, 2003 | 10:20 AM
DWolf's Avatar
DWolf
Myst
I have a add-a-leaf and 3 leaf mini pack for about 3.5" of lift and I have 315-75-16 pro comp allterran tires on stock wheels and yes they will rub in fuul turn and hit a bump. I think with aftermarket wheels you will have a wider offset and should not rub. I did have 305s with just the add-a-leaf (about 2' lift)and no mini pack and it did not rub
Don
Old Oct 29, 2003 | 10:23 PM
myst's Avatar
myst
Just put my add-a-leaf on raised front 2 1/4 inches. got 295's on 16x10 wheels and not rubbing. but i have a problem with the new springs, when driving down a dirt road i can here a dull thumping sound. took it to a off road shop and they said everything looked ok. any suggestions on that??
Old Oct 31, 2003 | 07:04 PM
DWolf's Avatar
DWolf
I also had a thumping right under my left foot felt like the shakle area after checking everything for tightness (and it was) I sprayed some lube on the round plastic pads at the end of the leaf srpings and it took care of it. It was just a little side to side movement in the leaf spring. Good luck
Don
