Intermittent starter issue
Old Mar 14, 2020 | 11:31 AM
The Old Truck's Avatar
The Old Truck
I have been having an intermittent starter issue. Everything works fine and then I jump in to start the truck and I get noise that sounds like the starter is not engaging the flywheel and the motor does not turn.
Should I just change the starter or solenoid or both? I don't want to wreck the flywheel. Would there be something else to look at?
Thanks,
Don,
Old Mar 14, 2020 | 12:43 PM
matthewq4b's Avatar
matthewq4b
Thanks,
Don,
Sounds like a starter issue, either worn bushings or worn brushes.
Old Mar 14, 2020 | 03:01 PM
Franklin2's Avatar
Franklin2
Or the clutch in the starter drive is bad. I vote changing the starter also.
Old Mar 14, 2020 | 04:17 PM
matthewq4b's Avatar
matthewq4b
Not likely as when the bendix's fail they usually just fail. All it takes is for them to slip once and the rollers get flat spotted.
Old Mar 14, 2020 | 07:34 PM
whisler's Avatar
whisler
Check the starter bolts for tightness.
Old Mar 15, 2020 | 07:40 PM
kenny nunez's Avatar
kenny nunez
Starter engagement
Over a period of time and mileage the crankshaft main bearing thrust shoulders wear and the crankshaft can move slightly back and forth, the starter thrust washers also wear along with the drive teeth. If you change the starter it would be very helpful to be sure the drive is a new one and not rebuilt. Replace it with a new drive. When a starter drive is rebuilt the teeth are ground back and refinished. Take a close look at a new drive and a rebuilt one, sometimes the teeth are ground back 1/8” or more. So what happens is the starter is at full speed before engagement and you get the grinding which will eventually kill the flywheel. And whichever # cylinders you have is where the flywheel stops every time.
Old Mar 16, 2020 | 08:37 PM
The Old Truck
Thank you all for the response. The starter seems tight, I will look into the new starter with the new drive.
Don,
Old Mar 25, 2020 | 04:34 PM
ulmapache's Avatar
ulmapache
Gonna hitch a ride on this thread...my starter sounds like there is a dead battery...thunk, thunk...but when I push it a bit, or hammer on the starter, it will work...going to R+R starter in the am, question: Do I have to stay with whatever is in the truck, or can I install a gear reduction type starter to spin that old diesel a bit faster...'84 F250, 6.9idi, 4sp manual Thx for the replies!
Old Mar 25, 2020 | 07:35 PM
Franklin2's Avatar
Franklin2
They had two different types of starters the factory used on the old diesels, and one of them was a gear reduction starter. You may already have one on it.
This place has one that has good ratings if money is a factor. https://www.dbelectrical.com/ I think they sell this same starter on Amazon.
Old Mar 25, 2020 | 08:17 PM
matthewq4b's Avatar
matthewq4b
Since it sounds like you have a drirect drive delco remy starter it may just need brushes. Hammering on the starter and it working is a good indication that the brushes are toast. Brushes are cheap and take about 5 mins to install once the starter is off. For a gear reduction unit go with the Mitsu unit.
Old Mar 26, 2020 | 12:01 AM
ulmapache's Avatar
ulmapache
Cool...if I were younger, I'd probably rebuild it..learned that in jr hi shop. Going to swap it out for new...want to make sure a gear reduction type will drop in even if the old one is direct drive...gotta spin that old diesel faster...thx much!
Old Mar 26, 2020 | 12:59 AM
1TonBasecamp's Avatar
1TonBasecamp
Might still be an easy swap, but my book says that the '83 and '84 used only the Delco starter, while the '85 to '87's were the ones with either an "original Mitsubishi" or "replacement Nippon Denso" starter.
Don't know if they wire up all three the same, or if you have to tweak things a bit, but it sounds like the others know their way around these 6.9's enough to get you there.
Good luck.
Paul
Old Mar 26, 2020 | 01:02 AM
1TonBasecamp
When the original starter in my '71 w/302 got old and tired of living, it was cluing me in by spinning, but not engaging the ring gear.
Started off by doing it once every few weeks, then got down to every few days. Until it just would no longer engage no matter what I did.
Replacement starter fixed it for the next 15 years or so.
Paul
Old Mar 26, 2020 | 06:02 AM
Franklin2's Avatar
Franklin2
No matter what starter he has, the old diesels used a starter with the solenoid on the starter itself. It almost sounds like the copper washer in the back of the solenoid that makes the connection to the starter motor is burnt up. He keeps hitting it till it finally makes connection.
But by this time the whole thing is probably worn out, a whole new starter would be a good thing. Those old diesels are hard on starters when a little something goes wrong with the engine.
Old Mar 26, 2020 | 11:42 AM
ulmapache's Avatar
ulmapache
Guess I'll find out when we pull the starter...hope I can get a gear reduction type in there, but if all I can use is direct drive...oh well...
