Wrong tank sent
Old Mar 13, 2020 | 06:00 AM
Ryanalofs's Avatar
Ryanalofs
Wrong tank sent
Hey all. The gas tank with the eec port on top was sent to me by mistake. Can the eec port be plugged since the filler neck also has a vent tube next to it? What can I do to not have to send it back and wait for the correct tank?
Old Mar 13, 2020 | 07:54 AM
Loosescrews's Avatar
Loosescrews
I believe the filler neck and vent are on opposite sides on the evap tank. Take a look.
Old Mar 13, 2020 | 09:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Ryanalofs
Hey all. The gas tank with the eec port on top was sent to me by mistake. Can the Evap/Em port be plugged since the filler neck also has a vent tube next to it? What can I do to not have to send it back and wait for the correct tank?
Evaporative Emission system abbreviated Evap/Em
EEC = Electronic Engine Control system - on-board computer. No Ford truck has this until the 1980's.
The Evap/Em tank has a hole in it adjacent to the sending unit for the fuel vapor valve. This valve and its o-ring were not furnished with the tank.
Evap/Em = NON vented fuel cap, unleaded fuel.
Old Mar 13, 2020 | 09:42 AM
Ryanalofs's Avatar
Ryanalofs
This hole at the top of the tank, is there a plug that anyone knows of so gas doesnt leak out?
Old Mar 13, 2020 | 10:30 AM
68Flareside240's Avatar
68Flareside240
If it was sent to you by mistake, I would get the right one sent to you, with a return label for that one.
Old Mar 13, 2020 | 10:44 AM
smle's Avatar
smle
And the nipples for your filler hoses are opposite between the evap and nonevap tanks.
Old Mar 13, 2020 | 01:35 PM
FuzzFace2's Avatar
FuzzFace2
If this is not a deal breaker then why not get the valve and gasket put a short gas hose on it with a blot in the end and call it good?
Dave ----
Old Mar 13, 2020 | 01:57 PM
NumberDummy
Dave ----
The valve has a nipple on it, just cap it off.
Old Mar 13, 2020 | 07:02 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on just get the valve that is suppose to go in the hole and cap it. As long as the filler neck and vent connection placement are correct for you.
Old Mar 13, 2020 | 07:21 PM
Ryanalofs's Avatar
Ryanalofs
The fillerneck is on the correct side. I will plug the hole on the top with either a bulkhead plug or an expansion plug.
Old Mar 13, 2020 | 07:23 PM
77&79F250's Avatar
77&79F250
I would plug it with 100% of what ever it calls for. You do not want a "it fits ok" to fall in later on.
Old Mar 13, 2020 | 07:29 PM
Ryanalofs's Avatar
Ryanalofs
You're right. The hole is 1 3/8 inch. I know theres an expansion plug that size. It'll barely fit relaxed. So when I tighten the nut, itll expand even more.
Old Mar 14, 2020 | 09:09 AM
John89's Avatar
John89
I would be wary of using a rubber expansion plug. Over time the rubber will degrade/crumble/dry rot and fall in the tank eventually letting air, water, dirt etc... in.
I think what is being mentioned for correct nipple placement is not L or R on tank, but front to back.
On our 78 the fill nipple is towards the front of the truck and the vent nipple is towards the back.
For your new tank, they are switched. If your truck doesn't match, you'll have to cross the vent hose over or under the filler hose. There is not a lot of room to do that.
Vent hose is just behind (towards the rear truck) the filler hose. Your new tank won't match this layout.
Old Mar 14, 2020 | 09:11 AM
alans77crew's Avatar
alans77crew
We received the same tank for my son's truck and didn't have the valve so I just cleaned the paint off and cut a piece of metal to cover the hole and soldered it up, then used Eastwood tank liner inside and out. worked great and no leaks. Just so ya know I line ALL tanks anymore with the crap they pass off for gas anymore I feel it's cheap insurance against corrosion.
Old Mar 14, 2020 | 10:00 AM
68Flareside240
Agreed John89, there's not a whole lot of room to the get the hoses where they need to go in the right configuration.
