460 High Flow Cats?
Old Mar 11, 2020 | 01:37 PM
RickyBerd's Avatar
RickyBerd
460 High Flow Cats?
What high flow cats do you guys run in your 460s? Can't seem to find anything under $100 for an engine this big.
Old Mar 11, 2020 | 04:46 PM
jas88's Avatar
jas88
I don't run a cat. My truck is over 25 years old so I took it out (no emissions testing in Texas for >25 YOA vehicles). The OEM cat is a big, ugly thing.
If your engine is not modified quite a bit, you don't need a "high-flow" cat IMO. I am not sure they could prove they flow any more than OEM in any case. Mostly you are just getting a new, clean cat.
Old Mar 11, 2020 | 05:38 PM
RickyBerd's Avatar
RickyBerd
I don't need emissions on my truck either, but I figured I'd at least do what I could to keep it legal without spending too much. It's kind of looking like I'll just go for the cat delete.
Old Mar 11, 2020 | 06:08 PM
sloopdog1's Avatar
sloopdog1
Poke a steel rod thru the cat to open it up, but leave it on the truck so that it looks like it is still doing it's job. Mine does not have to be emission tested either, but it has to have all of that stuff on the truck, APPEARING to be working.
Old Mar 12, 2020 | 02:43 PM
RickyBerd's Avatar
RickyBerd
That's an option. The main thing is that I'm doing a cat-back exhaust, upgrading to 3", which even with a gutted cat, it'd still be the bottleneck. Although it'd probably flow much better once gutted so it might be a solid interim solution until I dump the extra money into a high flow or decide to just cut it out. Mostly I'm just a pansy that doesn't want to get that super rare, but super expensive ticket for no cat.
Old Mar 12, 2020 | 02:47 PM
1TonBasecamp's Avatar
1TonBasecamp
I don't get tested anymore, but I've actually added cats to my older trucks with swapped-in EFI just to clean up the exhaust. I'm not worried about that last couple of horsepower, so a cat is a no-brainer for me.
I used Magnaflow brand high-flow cats, but I can't tell you anymore how much they cost. But using $100 bucks as your max outlay is going to limit you drastically I would expect. Unless someone has an unused one on Craigslist they no longer need, I can't imagine many cats for less than $100.
Not sure what they go for these days, but I'd still get one even if they were more than that. And I'm still always on a tight budget.
Good luck. But look on Craigslist and the for-sale forums hereabouts too. Just in case someone did not finish their project.
Paul
Old Mar 12, 2020 | 03:15 PM
rla2005's Avatar
rla2005
Universal Magnaflow 3" converter: Magnaflow 99109HM Summit Racing
~$118 USD plus tax/shipping. States it fits Chevy big blocks, should work on a Ford.
When I replaced the entire exhaust on my old 1992 F350 4x4 w/5.8L engine I used a Magnaflow 59929. No emission testing here, but I like to breathe clean air. At the time that converter was rated for a higher GVW, Magnaflow downgraded it a few years ago I noticed. The 99109HM may be the golden ticket you are looking for.
Old Mar 12, 2020 | 05:06 PM
1TonBasecamp
Same here. I was surprised at the improved smell on my '68.
When the '98 Explorer engine was installed, still 100% stock right down to the exhaust manifolds and EGR setup, it actually put out a surprisingly nasty exhaust smell.
Adding the cat took care of about 90% of that. Happier now for sure.
The '93 F150 actually smells surprisingly nasty right now too. Wonder if that means that the original cat has seen better days? Could also be a tired old air pump I suppose.
Going to replace the pump first, since I know it's in sad shape. If that doesn't do the job I'll replace the cat too.
Paul
Old Mar 12, 2020 | 06:37 PM
Diesel_Brad's Avatar
Diesel_Brad
I am pretty sure the one RLA listed is the one I have been running on my 460 truck for the past 18 years
Old Mar 13, 2020 | 09:11 AM
RickyBerd's Avatar
RickyBerd
Awesome, I went ahead and ordered the Magnaflow 99109 as well as the flange adapter from Bear River (https://www.bearriverconverters.stor...roduct-reviews) and should be able to do a full 3" exhaust from the manifold flange for under $350.
Old Mar 13, 2020 | 09:38 AM
rla2005's Avatar
rla2005
Nice find for the adapter. Because of that unique setup it makes the direct fit converters even more expensive.
Halloran1
Apr 9, 2012 11:53 PM
tvaughn
Exhaust Systems
Mar 1, 2004 05:45 PM
bigtruckman
1997 - 2003 F150
Sep 8, 2002 06:59 AM
Jesusfreak_01_02
Exhaust Systems
May 12, 2002 10:24 PM
