Replacement cat for 7.5L
Old Mar 10, 2020 | 06:55 PM
RickyBerd's Avatar
RickyBerd
I want to put a high flow cat in my '92 F250 with 460, I can't find any (cheap-ish) cats that are rated for anything more than 5.7L. Any suggestions? Truck is tagged historic so I guess I could just do a cat delete or gut it, but I'd rather keep it legal.
Old Mar 13, 2020 | 05:57 PM
torq'ta 5 8's Avatar
torq'ta 5 8
scavenger hunt at junkyard, and get one off a newer body style truck 2004 or newer trucks average hp was well over 300, and those cats are 3"(2 3/4") and cheaper than $100+ for new one, could prolly take whole exhaust just chunk muffler, find crew cab, long wheel base trucks, that much more piping
Old Mar 17, 2020 | 06:59 PM
V10man's Avatar
V10man
Just find a large body 3" in/out cat 16" or longer. Is yours bad? My 02 has 164,000 miles and my last emissions test my exhaust was clean.
Old Mar 18, 2020 | 07:26 AM
RickyBerd's Avatar
RickyBerd
Cat is still good, but I am upgrading to a 3" single exhaust, which would make the stock 2.25" cat a pretty major bottleneck. I ended up with the MagnaFlow 99109HM
Old Mar 23, 2020 | 10:44 AM
torq'ta 5 8
your stock cat is 2(pipes) in / 1(pipe) out how are you going to adapt to that
Old Mar 23, 2020 | 10:51 AM
RickyBerd's Avatar
RickyBerd
https://www.bearriverconverters.stor...-gasket-fx2016
Old Mar 23, 2020 | 12:37 PM
torq'ta 5 8
aaahhh...you think your old cat stopped up or getting there, lets us know if you notice a difference when you swap it
Old Mar 29, 2020 | 11:36 AM
RickyBerd's Avatar
RickyBerd
After pulling it off, the stock cat looked pretty clean which is kind of surprising for being almost 30 years old, granted the truck only has 101k on it. Anyhow, sold the stock cat for $175 which paid for over half the exhaust . I've noticed a bit of increased power but that might just be placebo. Will track the MPGs and see what I get. Noticed a little drone in the cab on the freeway but that's probably just from the exhaust tip not quite clearing the body extending that a couple inches should help. If not, I'm planning on soundproofing the cab anyhow.
Sounds damn good in my opinion.
96f150
1997 - 2003 F150
Oct 3, 2019 09:30 AM
61 uni
Aug 15, 2007 10:22 PM
Chippa
Exhaust Systems
Oct 22, 2004 02:04 PM
