Cooling System
Old Mar 10, 2020 | 10:49 AM
maandersonjr24's Avatar
maandersonjr24
Cooling System
1973 F250 with a 390FE 2WD. I have the original radiator in it but I don't have a fan shroud. This is going to be my daily driver until probably the end of summer. Whats a good way to make sure the engine stays cool? Just making sure the radiator is working properly? Definitely getting a fan shroud?
Old Mar 10, 2020 | 11:16 AM
1978f-250's Avatar
1978f-250
Do get the fan shroud, it's very important. Change out and replace the antifreeze mixture so you know what's in there.
Dennis
Old Mar 10, 2020 | 02:57 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1968/76 F100/350 360/390: Fan shroud reproduced by Carpenter, but there are TWO different types, because the Super Cooling radiator fan shroud has a larger opening radius.
There are also TWO different radiator supports with round headlamps, one was only used with the Super Cooling radiator.
Old Mar 10, 2020 | 05:57 PM
caravaggio2000's Avatar
caravaggio2000
I live in Florida and also have a 390fe with the fan shroud. Truck stays nice and cool. The only other thing I have is header wrap, which did lower the temperature a little. It probably won't make a huge difference, but also make sure your fresh air intake is hooked up so you are drawing cool air into the engine.
Vegas123
Aug 5, 2015 08:50 PM
Jupes
Apr 30, 2011 09:03 PM
cmoore99
Oct 4, 2004 12:10 PM
proeliator
Mar 19, 2003 03:29 PM
