Reverse Lights In Bumper
Old Mar 9, 2020 | 10:30 PM
2017-350's Avatar
2017-350
Where is the best place to tie in reverse lights that i am hunting in the bumper? in the actual tail light or in one of the trailer plugs in the bumper? I am also going to wire them to an up fitter switch...do i tie that in between the light and the splice for when the truck is in reverse?
Old Mar 9, 2020 | 11:00 PM
Carnac22's Avatar
Carnac22
Many ways to wire aux reverse lights. If they draw much power (non-LED) you need to use a relay - probably best to energize the relay by the back-up light and then use the up-fitter switch to break the connection also. That way you can only get back-up lights with the truck in reverse (and the up-fitter switch on). Pretty easy to bump the overhead switch and it the reverse lights are not wired through the reverse circuit you could cause an accident or at least be on the hook for a ticket.
Do not wire through the trailer plug wires - the truck will always think you have a trailer attached.
I'm sure that with a search about up-fitter switch wiring, you will find some detained wiring set-ups for what you want.
Jim
Old Mar 10, 2020 | 06:38 AM
Heathmc's Avatar
Heathmc
IMO the best route is to hardwire them to an upfitter switch so they can be controlled independent of the reverse lights. There are times I want to reverse without the sun on behind me and there are times I want the lights out while in park.
Old Mar 10, 2020 | 08:17 AM
maypo59's Avatar
maypo59
I just put mine on upfitter 2.
Old Mar 29, 2020 | 05:00 PM
SJC669's Avatar
SJC669
Confirming you can splice into the reverse light wire
Hey fellas. Just confirming you can splice into the reverse light wire if you want on these newer ones? On my '11 or '16, I tried that, and subsequently learned that you could not do that due to some electrical thingies LOL...
Towinrig
Electrical Systems/Wiring
Oct 26, 2018 06:47 PM
Socal82bronco
Feb 9, 2014 07:23 AM
Mikey D1016
2009 - 2014 F150
17
May 1, 2011 06:04 AM
zxkeller
Apr 26, 2008 05:26 PM
Kikwear
1978 - 1996 Big Bronco
Jan 31, 2004 12:42 PM
