!!!! No Start...
Old Mar 6, 2020 | 04:47 PM
afonda's Avatar
afonda
!!!! No Start...
Had the truck idling in the driveway... went in the house for a phone call... came out and the truck was not running. Turned the key... no start. WTF?
Fuel pressure gauge reads 65 . Coolant looks good. Temp gauges read normal.. so not overheating. Nothing obvious to see under the hood.
Any ideas?
Old Mar 6, 2020 | 05:26 PM
Brian Hanks's Avatar
Brian Hanks
Any ideas?
unplug the ICP and try again
Old Mar 6, 2020 | 05:29 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
If the wait to start light does not come on when you turn over the key, pull the fuel heater wire off the fuel bowl and replace the fuse. Pretty sure it is fuse 116, a 30A fuse for 2002. Do not replace wire to fuel bowl.
Old Mar 6, 2020 | 05:30 PM
afonda's Avatar
afonda
So I went out... unplugged the ICP.. fired right up... plugged the ICP back in... fired her up.. ran for about a minute and then she shut down.
There was oil in the ICP connection... not good im guessing.
She fired back up and currently the engine is idling with the ICP plugged in.
IDK...
Old Mar 6, 2020 | 05:38 PM
afonda's Avatar
afonda
update
The truck was idling just fine... went back outside after writing the last message and she was not running. I turned the key.. started up and then she shut down on her own. I unplugged the ICP again and still no start. Cranks good. no problem with starter or batteries.
Old Mar 6, 2020 | 05:55 PM
Brian Hanks
That’s weird. Sure sounded like a bad ICP. Do you have gauges?
I still think the ICP is part of your problem. It just might not be the only one.
Old Mar 6, 2020 | 06:04 PM
afonda's Avatar
afonda
I have fuel pressure and boost gauges. fuel pressure is good. no boost at idle obviously...
Just went back out... ICP unplugged... fired up. then shut down after 30 seconds... wont fire back up... I'm thinking CPS? ????
Old Mar 6, 2020 | 06:26 PM
Brian Hanks
possible. Without scan gauge (FORScan lite, etc) it will be impossible to know for sure and could just start throwing parts at it unfortunately. If you change sensors in these trucks you must only use motorcraft. Others don’t play well.
Old Mar 6, 2020 | 07:24 PM
Walleye Hunter's Avatar
Walleye Hunter
How 'bout the IPR? Is the tinnerman nut still on it and tight? If you cool the IPR with ice or spray air does it make a difference?
Old Mar 6, 2020 | 07:38 PM
afonda's Avatar
afonda
forscan...
what happened to forscan... it was on my PC now gone... can I download it again?
Old Mar 6, 2020 | 07:41 PM
afonda's Avatar
afonda
so I went out and it started up with the ICP plugged in... ran for about 20 mins and then just shut down. going to run a Forscan and get back to you all... thanks Andy
Old Mar 6, 2020 | 08:34 PM
Brian Hanks
Definitely do as walleye suggested as part of your initial troubleshooting
Old Mar 6, 2020 | 10:49 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
IPR...
Use a keyboard cleaner spray can upside down and cool off the coil when it shuts off. Visually check for the nut on the end as well as Mark said above.
Your ICP is also bad if there is oil in the connector. Motorcraft or International sensors only please sir!
Old Mar 7, 2020 | 07:48 AM
afonda's Avatar
afonda
I remember that IPR being a real B***** to get to. I will check it out.
Getting new ICP today from Ford.
Old Mar 7, 2020 | 10:00 AM
afonda's Avatar
afonda
Just pulled these codes from FORskin.... haha
Code: P1280 - Injector Control Pressure Failure
Code: P1316 - Injector Driver Module Codes Detected
Module: Powertrain Control Module
Diagnostic Trouble Code details
Injector circuit, IDM codes detected.
--Possible Causes--
- EF circuit fault.
- Fuel delivery command signal (FDCS) circuit fault.
- Damaged injector.
- Damaged IDM.
- Damaged PCM.
Code: P0344 - Camshaft Position Sensor A Circuit Intermittent (Bank 1 or single sensor)
Code: P0340 - CMP circuit fault.
Code: P1876 - Transfer Case 2-Wheel Drive Solenoid Circuit Open Or Short To Ground
