locker rear end
Old Mar 6, 2020 | 01:55 PM
zonk11's Avatar
zonk11
4wd Low
locker rear end
I have been looking for a rear in and I was offered a 99 4wd ford exployer (free) it has the gears I wanted 3.73 but it is a locker. I don't think I want a locker rear end can I change anything to make this one a non rocker? Is this a dumb idea or should I just go with a locker. This is going into a 52 f1 crusier.
Old Mar 6, 2020 | 02:09 PM
56panelford's Avatar
56panelford
I put an Auburn locker in mine with 3.73 in my Explorer differential and it presents no problem. I'd jump on it before someone else does..are you sure it's not just the factory limited slip..?
Old Mar 6, 2020 | 02:11 PM
52 Merc's Avatar
52 Merc
I'm not sure what you mean by 'locker'? Unless it's been modified to some type of aftermarket differential, it may have the factory limited slip diff, which is highly desirable, and you'll never notice any ill-effects in your application.
Old Mar 6, 2020 | 02:53 PM
00t444e's Avatar
00t444e
If it's factory it isn't a locker, it's a limited slip that doesn't work that great.
Old Mar 6, 2020 | 04:42 PM
zonk11's Avatar
zonk11
4wd Low
on the tag is says 3 L 73 I thought the L meant locker
Old Mar 6, 2020 | 05:34 PM
Swank56's Avatar
Swank56
Nope
“L” is limited slip
Old Mar 6, 2020 | 06:12 PM
zonk11's Avatar
zonk11
4wd Low
thanks for the info
Old Mar 7, 2020 | 07:51 AM
mtflat's Avatar
mtflat
"Locker" is generally a Chevy term. Ford chose to use "limited slip" - similar idea but they are different.
A true locker is basically a solid rear axle and they are only good for drag racing and extreme off-road applications. There are YouTube vids out there that show the difference in simple terms.
Limited slip has a clutch pack in the differential that tightens up if one wheel looses traction, then when it's not needed it releases and acts like an open drive diff.
Old Mar 7, 2020 | 08:35 AM
00t444e's Avatar
00t444e
Locker and Limited slip are two different things regardless of the manufacturer. Lockers are either automatic that remain locked and unlock when you go around corners like a Detroit locker, Grizzly locker, or any of the lunchbox lockers, or they are selectable they work like an open differential until you press a button then they fully lock like a Spool. Limited slips use clutches or gears to try to keep both wheels spinning at the same speed, buy they don't have the ability to fully lock so in extreme situations you will still end up spinning one wheel like an open differential. What you described as a "true locker" where both wheels turn at the same speed all the time isn't a locker, that is a spool, for it to be considered a locker it has to have the ability to unlock.
Old Mar 7, 2020 | 08:56 AM
CharlieLed's Avatar
CharlieLed
Wanting to eliminate the TracLoc in a rearend is like asking your boss to reduce your pay. That 8.8 is a sweet setup, run it you'll like it!
Old Mar 8, 2020 | 04:03 AM
1956_F100's Avatar
1956_F100
It should work fine. When you fill it with gear oil be certain to add Friction Modifier. Get the stuff Ford sells or sold through Ford Racing. It basically helps the clutches slip a little smoother when making turns. Without it you will get chattering or growling from the rear axle when making turns.
The friction modifiers retail parts stores sell doesn't work as good.
Old Mar 8, 2020 | 12:25 PM
mtflat's Avatar
mtflat
Thanks for the clarification - you said it a lot better. It's been decades since I messed with a limited slip 9".
Old Mar 8, 2020 | 04:21 PM
52 Merc's Avatar
52 Merc
This is the best info in this thread. and is exactly correct. If you have a Ford TractionLoc diff it's necessary to use the Ford friction modifier. As stated above, anything else does not work, or at least not as good. Failing to heed this will require one to drain their rear and add new lube with the Ford modifier. You don't have to ask me how I know.
Old Mar 8, 2020 | 04:48 PM
kenny nunez's Avatar
kenny nunez
Limited slip
I had read somewhere in a Ford service manual how to break any glazing from the plates to go in a parking lot and back up in a figure 8 pattern several times.
Old Mar 8, 2020 | 05:24 PM
00t444e's Avatar
00t444e
All the friction modifier does is make the clutches slip easier which makes the unit less effective. When I rebuild one I typically leave the friction modifier out unless it's locking up to tight around corners or the clutches are making noise.
