Police Mode - delayed starting
Old Mar 6, 2020 | 12:27 PM
Flyct's Avatar
Flyct
FTE Community Team
My 2019;F350 has “Police Mode” enabled by default where previous years required FORScan to activate it.
Today I went to hook up my 5th wheel. I left the engine running and took keys with me to unlock the 5th wheel. When I got back so I could back the truck up to hitch the trailer, the gear shift wouldn’t come out of park even though I had my keys with me.
I tried to turn the truck off and on but still wouldn’t budge. I exited the truck, locked it, unlocked in, got back in , started the engine and iThe shifter still would not budge.
i had to exit the truck, lock it and wait 5 minutes before I was able to start it and get it out of park.
Good thing I wasn’t blocking traffic.
I thought about disabling Police Mode with FORScan but decided that next time I’ll turn the truck engine off before exiting with my keys.
Old Mar 6, 2020 | 01:15 PM
mhoefer's Avatar
mhoefer
Did say it couldn't detect key on the dash when you got back in? What I do is say OK, and put key in the spot to then make sure I can shift from Park. I am in and out of the truck a fair bit and have never had it not fairly quickly detect my key/FOB and let me shift. Mines a 2017 in signature, and its had this on since early 2017 in Police Mode.
Old Mar 6, 2020 | 01:21 PM
C12H24's Avatar
C12H24
It has happened to others with earlier trucks. There is at least one thread on the issue. It may be worth your while to search for it. I don't have any recollection if there was a resolution beyond restoring the module to factory settings through Forscan since this can, as you point out, result in some major inconvenience.
I was considering turning on the feature but the issues were common enough to cause me to change my mind.
Old Mar 6, 2020 | 03:34 PM
ForeverFixing's Avatar
ForeverFixing
When my 2017 would not go into drive I did the same as you. I even left it for half an hour while shopping and came back. No change. Then out of frustration I tried everything I could think of. I put on the E brake and it shifted out of park. When I disabled it the driver's seat heat went back to normal operation. It kept turning on the heated seat by itself. Somehow things are related. I want to try it again when I will be close to home for a while.
fabchef
Sep 11, 2017 08:35 AM
nrh 6.7
Nov 2, 2015 09:22 AM
EvanBly
Transit Connect
44
Oct 30, 2015 04:17 PM
brickyiowa
2004 - 2008 F150
May 31, 2013 07:24 PM
